2 members (DJC, Zach),
295
54
Posts837,253
Posts: 39 Likes: 5
Posts: 39 Likes: 5 |
I wonder if anyone can help with my 1998 4/4 blowing the fuel pump fuse on startup. It doesn’t happen all the time, but often enough to be annoying. It’s fitted with a 15 amp fuse, is this the correct size? Once running the car runs perfectly. Thanks, Chris
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Fuse box info here from GoMog FusesIntermittent fail could be a fuel pump on the way out
Posts: 8,655 Likes: 407
Posts: 8,655 Likes: 407 |
15 amp fusing sounds right for a fuel pump Chris. If it's blowing then excessive load on pump itself due to dirt or simply as John suggests pump is on its way out. Can't say definitively as 1998 wiring diagrams where available are a bit hit and miss but there doesn't appear to be a fuel pump relay. Doubt if such would be the cause anyway.
Posts: 535 Likes: 1
Posts: 535 Likes: 1 |
You could try a full dose of Seafoam in a full tank of fuel which will clean and lubricate the whole fuel system so if it the fuel pump which is a bit bunged up this could work. You can get Seafoam on Amazon - great stuff been using it for years and use a small dose permanently in my older motorcycles.
Cheers, Paul
Posts: 6,538 |
Never heard of Seafoam before. But just ordered off eBay…seems well worth a go! Thanks for posting.
Neil
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
Never heard of Seafoam before. But just ordered off eBay…seems well worth a go! Thanks for posting. Used it on several bikes with some success. Very popular stateside and now commonly available in the UK.
