Topics49,909
Posts838,126
Posts: 161 |
Hello all,
My ‘66 Plus 4 has two little side lamps on each wing right in front of the mirrors. They are Lucas L516s.
Has anyone rebuilt theirs? There is a little rubber gasket between the lens and the front chrome ring. I am fairly sure it’s Lucas part #573619.
I’m have trouble sourcing an equivalent. I tried some o-rings, 28 mm OD, 24 mm ID, 2 mm wide. They don’t work. Too thick to fit the bulb mount in, which locks the whole thing together. I think it should be a bit wider, and a bit flatter. What have people used?
-Nelson
- Nelson
1966 Plus 4 RHD
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Probaby easiest to either make one or buy complete new lamp for spares as here.
Posts: 58 |
I used O rings, from either a box of metric sized or imperial sized. The O rings are differing thickness, therefor trial and error required. Hope this helps.
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
I used black silicone sealant applied with a syringe
Works very well
Arwyn
Posts: 161 |
Thanks Arwyn, I was thinking of that. Do you squeeze it in and then let it set up inside the ring before putting back together?
- Nelson
1966 Plus 4 RHD
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
I used some viton O rings. Measured up the old ones, and got new from eBay. Unfortunately it was a few years ago so can't find the size on my purchase history.
Thanks Arwyn, I was thinking of that. Do you squeeze it in and then let it set up inside the ring before putting back together? A tip when using sealant to form a gasket learnt from my yotty years. Apply generously then clamp item down gently wiping off excess. Wait at least 24 hours to go off then tighten fully. This saves all the sealant being squeezed out at first application.
Posts: 2,121 Likes: 71
Posts: 2,121 Likes: 71 |
Perhaps some Thanks Arwyn, I was thinking of that. Do you squeeze it in and then let it set up inside the ring before putting back together? A tip when using sealant to form a gasket learnt from my yotty years. Apply generously then clamp item down gently wiping off excess. Wait at least 24 hours to go off then tighten fully. This saves all the sealant being squeezed out at first application. Perhaps some plastic wrap between the silicone and the care would be usefull. Silicone is not the best fiend in paint shops...
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
I posted this in the washer bottle grommet topic. You could make your own. I bought some round section O-ring material for a job a while back. Cut to length for the circumference you need and superglue to connect the ends. I have a box of O-rings but none fitted so bought the right diameter( thickness). If I remember correctly it was sold by the metre and not expensive. I’ll see if I can find details. A google search is another option.
Posts: 8,701 Likes: 501
Posts: 8,701 Likes: 501 |
If you use an O ring that's too small & stretch it over the item you effectively reduce the diameter of the rubber, which can be useful...well until it goes ping
