7 members (Jeffpee, Paul F, RibbleAdventures, Ruut Bianchi, teknome, Bishmog, dogmog), 565 guests, and 43 robots.
John V6 83
+8Rich 68
DaveW 67
Luddite 58
9,203 Registered Users
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Glitch
brake reaction stay fitting
by Caveman, July 15
BHM Breakfastclub 5/7/2025
by DirkM, July 13
Parrot upgrade
Parrot upgrade
by Mr Mogoo, June 19
Topics48,331
Posts812,877
Members9,203
kamo30
Page 2 of 4 1 2 3 4
I had the same issue, it doesn’t have a positive release location. I found that “jiggling it” when the tab is in the open position does the trick.
Mike
1982 4/4
1999 +4
2004 Roadster S1
2010 Roadster S2
2021 Plus 6
I am posting these photos for Andy. It does look a bit Mickey Mouse to me.
He told me:-
"Hi John,
Here is the photograph and the diagram extracted from the manual. Photograph shows how mine looks when trying to open it. The diagram from the manual shows how it should look.
A picture paints a thousand words and al that!!
Cheers,
Andy"
2025 MG ZS EV aka Trigger
Thank you for posting, John.
Andy
2022 Plus Four / San Marino Blue
I have a late Trad Roadster fitted with this new type of fuel cap. I have had the same issues with mine not always locking shut. My dealer greased it and it's generally better now, but not perfect.
David
2020 Roadster 3.7 Dove Grey.
Just talked at lunch to a plus four owner who has the same issue
Try some silicone grease on the inner plastic parts that rotate against each other & wipe a thin layer inside the filler socket too, I have to do the Roadster every 6 months or so
Good evening.
I am having the same or similar problem.
In the petrol station today wondering if I can fill her up!
Jiggling works but not really sure what is happening!
Let's face it, it is just a poor piece of design.
I did investigate converting mine to a Monza style filler only to discover the same pressed steel tab arrangement hiding underneath the Monza outer cap!
Andy
Check that in refitting the retaining cable is aligned so that it retracts through the breather holes properly - if not it fouls the housing of the cap making it difficult to open. The breather plate rotates - on mine the cable needs to be in the six o’clock position to slide away easily.
Had lunch today with a few members of the Morgan Sports Car Club and it appears most CX chassis owners have trouble with the filler cap. My table chum told me there is a factory crude fix, in that part of the metal inside the cap is removed. He has had no subsequent problems.
Page 2 of 4 1 2 3 4
