6 members (+8Rich, Clipper, Davetherave, MartO, TBM, vincentvg), 296 guests, and 94 robots.
+8Rich 79
Topics49,871
Posts837,683
Rudolf
Page 1 of 5 1 2 3 4 5
#758964 21/10/22 03:15 PM
I want to fit a column mounted indicator switch to my 1969 4/4. Tried various models but insufficient room between steering wheel and dash. Any ideas please
The original Morgan column switch came from a Triumph Herald IIRC, but a standard one won't fit, you need to put an S bend into the shaft. This is a pretty fraught exercise, since (1) they are quite expensive and (2) there's a danger of kinking the tube.
I've done it twice now, I wrapped the stem in spiral banding to protect it and used the jaws of my bench vice to brace it whilst I put the bends in.
TBM Online Content
I think it was Ford Transit, but any BL one can be made to fit (I have one from an Austin Mini). However, I'm not sure how they'd fit on a '69 which has the indicator on a dash toggle switch I think.
You may have to bite the bullet and fettle the dash to make it fit. Column switches are so much easier - I've added a wiper column switch to mine as well.
This is the Welcome Forum.
You should post this in Classic Morgans Forum. You'll get more replies there.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
Thank you for your kind replies
Original was Ford Transit, MkII Cortina may be similar too but not sure.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Thanks
The difficult you will have is with the steering column.
The pre 1970/1971 cars used a one piece steering column, the later cars used the two piece steering column.
The one piece steering column has absolutely no provision for a cam to cancel the indicator so you will probably need to rig up some sort of warning buzzer or bleeper to remind you to cancel the signal!!
Arwyn
I suggest that you have a look in the Car Builders Solutions catalogue, lots to choose from.
Jack
1985 4/4 T/C 4 seater Royal Ivory
1934 F Type
2018 Pembleton SuperSport (self built).
Switch is courtesy of Ford Transit Mk1, Ford Corsair and a version of the Bedford CF.
If you know where to look and the right part numbers you can pick them up for less than 20 quid
Arwyn
