8 members (Jon G4LJW, MATTMOG, Luddite, Tom Sayles, Hamwich, DCH, Davetherave, RedThree),
207
126
Topics49,872
Posts837,687
Posts: 6,672 Likes: 438
Posts: 6,672 Likes: 438 |
Anyway back to the thread.
You can pick up a Transit one on eBay occasionally, and the odd NOS autojumble if you're happy ploughing through boxes. However there are a whole stack of Lucas ones of similar size and shape but you will have to chop the plug off and rewire.
This shouldn't be an issue for the OP as they are fitting one to a car that originally came without one, rather than replacing like for like. As Arwyn said, the issue will be fitting it in the space you have and then remembering to cancel it!
You can get buzzers to help - I have one which buzzers after about 8 clicks, useful when changing lanes etc. It also mutes when the brake is applied so stops you getting irritated. Fairly cheap from eBay - search for motorbike indicator warnings.
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
The other issue you will have is stopping the switch sliding around the steering column. If you look carefully at a Lucas 119SA indicator switch, they have a little plastic 'pip' cast into the switch body This fits into a cut out on the steering column and stops the switch moving around. The OP will need to replicate this somehow! The only options I can thing of are to drill into the outer steering column or maybe make up a pierced brass plate which can be soldered to the steering column. If you try to over tighten the retaining screws to stop it rotating then sure as eggs is eggs, you will crack the switch body Arwyn
Posts: 5,588 Likes: 603
Posts: 5,588 Likes: 603 |
Might a couple of turns of self-amalgamating tape round the column work? ... the pip should dig into it and be less inclined to slip and its stickiness should stop the switch turning unless the car gets lent to a gorilla ?
Posts: 12,262 Likes: 320
Posts: 12,262 Likes: 320 |
Or, if one remembers reading Zen and the Art of Motorcycle Maintenance, a shim made from an aluminium drinks can?
Posts: 923 Likes: 47
Posts: 923 Likes: 47 |
Or, if one remembers reading Zen and the Art of Motorcycle Maintenance... It's Tim isn't it....?Much better gentlemen.  This thread became an example of the collegiate format. Much more productive and safer for all concerned. Its all up on gomog, not a perfect source but even I use it. I have gone through five of these thingies with my trads. I kept the broken ones but have yet to find a use for them Definitely a weak point. However, the part number that most are using is a minor variant of that listed here. Lucas SQB119. The Lucas people lists them being used on the AC 3000 ME, 1979 to 1985, the Triumph Dolomite (all),1976 to 1981 . the Triumph Dolomite Sprint, 1973 to 1981 and the Triumph 2000 2500, 1975 to 1976 though there are many very similar controls Lucas hey made used on other vehicle. They are merely not exactly what Morgan used. If one googles "Lucas SQB119" one will find many sources I haven't had a problem yet. Here is one available from a search I did 2 minutes ago. I assume it is wanted in the UK, right? Of course, the prices vary wildly. I have not always been required to bend the fragile stalk. I broke the first one 25 years ago, and learned to use a tube bender since. They cost a mere 10 quid and you will find you will inevitably use it more than once. https://amzn.to/3THtd22 or https://www.flexolite.co.uk/products/sqb119-indicator-switch-for-morgan-triumph-sqb119 or or https://www.ebay.co.uk/itm/232450675596 Melvyn sells them (he calls them ELS087) he pre-bends them for you. Lastly 21 years of Morgan trad friends will adore you when you lend the bender to them or spend the 10 seconds necessary to help the. The other stalk control it mates to, (the windscreen wiper one...) fails less but it is another story. Please note Arwyn's caution about tightening the holding screwsI always have one in spares, for two reasons. 1. They will fail without warning, and 2. eventually supply might dry up and I might need a bit of time to source a replacement. Actually, I have mused that the entire column is less than stellar, (their collapsible feature breaks and their control stalks are neither great nor good looking. I have been lazily investigating replacement options, most of which come with any choice of column controls one could want including a tilt feature that does away with the need for he Long Doors' pushed forward dash and creates even more steering wheel clearance for larger Morgan tummies.  The stalks are metal. L
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
So, I just replaced my steering wheel after the old boss broke, and I have broken the "pip" that keeps the stalk assembly rotating. I'm currently relying on the shroud assembly holding it in place, which allows the cancel system to operate. I'm looking I thi nk for Discovery 2 stalks for my 03 +8, but without the rearscreen wipe/wash. although I guess one would do with rewiring?
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Not sure about later indicator stalks. The ones linked above are not the same as the earlier Morgan ones either. The early ones have no symbols on the stalks. Google MK3 Mini and you'll see. The Mini ones are shorter than the Transit ones but fit easily without needing a bend. ![[Linked Image]](https://www.tm-img.com/images/2020/09/22/BwkJ5ejepL6KrvcGD92VGNOm3iKJZALAj8Cz7GE1wEqPAObjD0bzO57OtKoH28ehYVlIw9F2hmQIqY5VMIn4qszlzlXciR8q9OPZjMP88-9HPfftKSK4qrULhIlEVjUWpkOB5W8rADi3E46TtBsPjn19nVbpYTDuyFag1KS-_A50yDxLXJ6V9Ku9K-whvP5iYe5ziBQM.jpg)
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Might be wrong Phil, but I think you should be looking at Freelander stalks for a '93 car. Probably the same as Disco ones, but at a lower price!  (and we're still in the wrong section of the forum  )
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
So, I just replaced my steering wheel after the old boss broke, and I have broken the "pip" that keeps the stalk assembly rotating. I'm currently relying on the shroud assembly holding it in place, which allows the cancel system to operate. I'm looking I thi nk for Discovery 2 stalks for my 03 +8, but without the rearscreen wipe/wash. although I guess one would do with rewiring? This are the Disco 2 stalks. I had just to replace the slip contakt on my ยด05 4/4 because it was broken and scatched the slip ring which had fallen off. I had some spare parts in my shelf because I needet them when my bespoke stalks where broken (the silver one at the top of the picture). My currant MorganPark stalk conversion seem to be more stable. ![[Linked Image]](https://tm-img.com/images/2022/10/22/column-stalks.jpg)
Thanks BM, that's the one on mine. (Middle item with the screw thingy) I'll look out and get a spare now for the shelf. Phil
