0 members (),
203
89
Topics49,847
Posts837,389
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Thanks Jon, they are £15 ish cheaper, but it’s the wing brackets that cost more than the spots lights.
Craig Jezz
Posts: 1,046 Likes: 148
Posts: 1,046 Likes: 148 |
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
I had been thinking about mounting some to the back of the overiders, it would require a pair of brackets making up that brings the mount back and sideways toward the grill, but looks possible. Has anyone already attempted this? Only thoughts are the OE overriders have very flimsy mounts when it comes to sideways movement so lamps would be all over the place on bumps. Mine modified by Wolf to fit through their valance also have a stainless bracing bar they supplied which fits between the two mounts to really stiffen them up.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
For a while, Ledgerwood sold a stainless spotlamp bracket which fitted behind the number plate box, with two small spotlights on each end of the box.
The over rider brackets can easily be beefed up using a flat sheet of aluminium between them. If you're really lucky the predrilled holes will already be on the inside.
Posts: 177 Likes: 12
Posts: 177 Likes: 12 |
Thanks for the insights.
I'll take another look at the Overrider brackets stability and talk to Ledgerwood, I had considered mounting to the Badge Bar but it wasn't wide enough so removed it.
Anyone got a picture of the Ledgerwood setup?
Regards
Mark 2015 +4 Ferrari Le Mans Blue
I put one on here Mark way back around 2010. I'll see if I can find it. I'm struggling to find the image, but check this out: http://www.talkmorgan.com/ubbthreads.php/topics/72594/Spot_Light_Brackets_for_cars_w
Thanks Dave, that's really interesting. The bracket is probably what I was thinking about, pity it's not available to buy.
Send Keith a PM, he will have the drawings I expect.
Posts: 81 Likes: 1
Posts: 81 Likes: 1 |
I quite fancy spots fitted to my 4/4, but a little worried about holes in the wings I nearly bought these ones at Williams back in March whilst having a service. I do think they would look good ? ![[Linked Image]](https://tm-img.com/images/2022/10/25/A314CA85-DEB6-439E-850E-26B93465665F.jpg) Do it Craig they look ace
Kevin Davies
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
They look nice, Lucas did a spot / foglamp version that looked very similar with a sort of chrome nipple in the middle of the lens, but they are quite rare now Cheers Jon, it's all about the nipples  ![[Linked Image]](https://i.ibb.co/R4tfbd4/Marchal-672-682-with-amber-bulbs-Nipples-1.jpg) ![[Linked Image]](https://i.ibb.co/tJvmS8q/Marchal-672-682-with-amber-bulbs-Nipples-2.jpg) Seeing as it's a bit grim up north today and I'm bored, I thought I'd show off my classic Lucas nipples ![[Linked Image]](https://www.tm-img.com/images/2022/10/29/Spotlights-1.md.jpg)
