6 members (John Winn, Luddite, DJC, stumog, How, Graham, G4FUJ), 420 guests, and 84 robots.
Sagging Hood
Topics49,857
Posts837,462
Page 3 of 4 1 2 3 4
Craig, I bet these are way more sensibly priced than a Mog dealer, and they're stainless too...
https://www.carbuilder.com/uk/stainless-steel-driving-lamps-125mm-5-pair
Thanks Jon, they are £15 ish cheaper, but it’s the wing brackets that cost more than the spots lights.
Craig Jezz
They look nice, Lucas did a spot / foglamp version that looked very similar with a sort of chrome nipple in the middle of the lens, but they are quite rare now
Cheers Jon, it's all about the nipples laugh2
Apparently they're even more pronounced in cold waether getcoat
These fog lights are Marchal 670/680 replicas, not cheap but still French made and excellent quality, often used in period on Ferrari 250s, Maserati 3500s and Facel Vegas but most commonly seen or Porsche 356s.
The secret to the mystical golden glow is clear lenses covering the correct Marchal yellow globe bulb.
The effect is rather beguiling, romatic, nay enchanting even cloud9
The mystical golden glow should work well against Monty's Sport Green paint and will tie in nicely with the brass and gold details I've been adding.
Originally Posted by Mark666
I had been thinking about mounting some to the back of the overiders, it would require a pair of brackets making up that brings the mount back and sideways toward the grill, but looks possible. Has anyone already attempted this?
Only thoughts are the OE overriders have very flimsy mounts when it comes to sideways movement so lamps would be all over the place on bumps. Mine modified by Wolf to fit through their valance also have a stainless bracing bar they supplied which fits between the two mounts to really stiffen them up.
For a while, Ledgerwood sold a stainless spotlamp bracket which fitted behind the number plate box, with two small spotlights on each end of the box.
The over rider brackets can easily be beefed up using a flat sheet of aluminium between them. If you're really lucky the predrilled holes will already be on the inside.
Thanks for the insights.
I'll take another look at the Overrider brackets stability and talk to Ledgerwood, I had considered mounting to the Badge Bar but it wasn't wide enough so removed it.
Anyone got a picture of the Ledgerwood setup?
Regards
Mark
2015 +4 Ferrari Le Mans Blue
I put one on here Mark way back around 2010. I'll see if I can find it.
I'm struggling to find the image, but check this out:
http://www.talkmorgan.com/ubbthreads.php/topics/72594/Spot_Light_Brackets_for_cars_w
Thanks Dave, that's really interesting. The bracket is probably what I was thinking about, pity it's not available to buy.
Mark
Send Keith a PM, he will have the drawings I expect.
Originally Posted by Craig Jezz
I quite fancy spots fitted to my 4/4, but a little worried about holes in the wings
I nearly bought these ones at Williams back in March whilst having a service. I do think they would look good ?
Do it Craig they look ace smile
Kevin Davies
Seeing as it's a bit grim up north today and I'm bored, I thought I'd show off my classic Lucas nipples
Page 3 of 4 1 2 3 4
