1 members (Robbie), 290 guests, and 38 robots.
+8Rich 92
Topics49,837
Posts837,286
Page 1 of 6 1 2 3 4 5 6
Hi All,
Anyone know what the 'real' torque setting is for the single wheel retaining nut is for spoked wheels?
The handbook is somewhat vague with the instruction 'hammer tight'! How very 'Morgan'!
Andy
2022 Plus Four / San Marino Blue
Hello Andy
perhaps this link helps.
This factory makes som of the Morgan whire wheels.
Torque for wire wheels
Regards von Germany
Bernt
Hi Bernt,
Thank you for that. 102Nm sounds about right. I was going to call the technical people at customer services at the factory but knew common sense would prevail on this forum!
Kind regards,
Andy
Andy
HJF Offline
That link is for conventional wheel bolts
For my S1 Roadster it was 80Nm. I checked with MMC . This is for alloys not for wire wheels.
HJF Offline
I have assumed that the original poster is talking about knock on centrelock wire wheels? If so 80Nm would probably result in them falling off
Sorry!
Here the link for Knock-on centre caps - not the torque Info you want frown2
Fitting wire wheels
Oh sorry. I don't think folk used torque spanners on wires. Please ignore the 80Nm.
For wires they need to be tight.
Sorry!
Fitting centre-lock wire wheels
This is new to me too, my car is getting wire wheels too...
Wire wheels this link works
Go down to the bottom of the page, it says "don't overtighten them" and "As long as the hubs are fitted correctly then the spinners will self-tighten and lock as the car is driving"
Morgan Plus Four
Metallic Emerald Green and Pebble Biscuit, 'clutchless'
One of the last MY22
The page linked to has the following line:
Originally Posted by MWS
There are no recommended torque settings for spinners and the exact number of turns will vary from one vehicle to the next.
I have always relied on a couple of knocks with the supplied hammer or a light tweak with the breaker bar I use for removal. They do self tighten in use - to the extent that mine can be tricky to remove as my painted wire wheels “grab” the nuts.
As the text on the MWS site says:
It is very important not to over-tighten as the threads are easily damaged.
Costock, UK
Disco 5
