Topics49,841
Posts837,321
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Does it lock up when brakes applied hard? They sure look good and also easy to clean.
Can you change the pads without removing the unit?
Posts: 960 Likes: 21
Posts: 960 Likes: 21 |
If you brake hard you'll block the front tyres before the rear one. But a fraction of a second later (according to my ears) the rear blocks too. But resuming: yes you can block it if apply a hard foot on the pedal. About changing the brake pads, you need to remove the wheel, I guess. I'll ask Steve and Craig, but looking at the pictures, there is not much room to change the pads with the wheel on.
Thanks Javier.
Sure a nice setup.
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Congrats Javier - you are certainly pressing the upgrade buttons! Did you consider doing the Empire Kit with the Ohlins?
Congrats Javier - you are certainly pressing the upgrade buttons! Did you consider doing the Empire Kit with the Ohlins? Thanks!  Mine is a late 2019 unit, Finished to be manufactured in December 2019 and registered in January 2020. It already has the comfort kit and handles pretty well. No need of the Empire Kit as far as I know
Posts: 131 |
Glad you like the Ohlins. It's hard to describe the improvement in empirical terms but as you say, anyone who drives hard, long or weighted will appreciate the investment. In my opinion, they transform the car from an agricultural to dynamic suspension.
'17 M3W (BRG) '03 Plus 8 35th Anniversary (BRG) '08 Ural Patrol (BRG) '21 Vespa 'Racing 60' (BRG)
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Javier
yes it is a veeeery long post so i read the first part first.
It is an interesting post. It is inspiring how much work has been put into the road book.
