5 members (BHV, JohnHarris, Mike D, Chris Cosher, jbk), 248 guests, and 36 robots.
+8Rich 102
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,256
Smed., Spanner Juggler
Page 17 of 20 1 2 15 16 17 18 19 20
Latest update of the Alternative Parts List is here: https://www.dropbox.com/s/uidddziz6gt10wo/Update%2013%20PDF.pdf?dl=0
Update includes a more readable section on engine sensors and info about sump plug repairs (thanks Bunny).
If you know of anything that can be added to the list to help other owners, please let me know. Same applies to anything you find incorrect, I don't check out everything added but accept the information I am given from other owners as true.
Thanks Ian thumbs
Red Leader drive
JMD Offline
Another vote of thanks for this invaluable resource....
Thank you, Ian! Its what gives me the confidence (here in the States) to keep motoring.
'17 M3W (BRG)
'03 Plus 8 35th Anniversary (BRG)
'08 Ural Patrol (BRG)
'21 Vespa 'Racing 60' (BRG)
Apologies, I don't see this in the list.Domeone might want to check my sleuthing.
It is part 35 in the 2012-2014 parts book. Part 22 in the 2014+ parts book
35 K130016 O.RING OIL FILTER HOUSING
S&s parts:
50-4066
50-8005
HD parts:
??? Listed as a replacement part for 2 hd models in the s&s catalog but no hd part given.
11168A
Hello Divine and congratulations on your first TM post. Looking at the parts diagram, it's two O rings, one looks shaped but that will be the shape formed by the grove it sits in. I don't have any details on them but they will be standard Viton O rings. Now looking at the S&S parts book, the round O ring (item 31) is listed as size -017 and the shaped one (item 32) as size -022 but I cannot identify those numbers for sure. If you measure them up for section size and inside/outside diameter they are all available from a number of sources, such as eBay or Bearing King.
Once you know the sizes please let me know and I will add the details to the next list update. That won't help you but it will make things easier for the next person who has to change them for a leak and making M3W ownership easier is the idea.
Does this help?
Left column has 017 and 022 specs
Thanks for that P964 👍. Every day is a learning day, they are BS017 and BS022 Viton seals and cost about 40p each on Bearing King in the UK.
Latest update of the M3W Alternative Parts List is here: https://www.dropbox.com/scl/fi/n4vo...rlkey=ph41ye2o0at74jgqhem9erzrk&dl=0
Update includes engine oil pressure sensor info, oil filter housing to crankcase seals , oil tank/crankcase alternative vent info, alternative front indicators, luggage rack suction cap.
As always, if you know of anything that fits or works better for the M3W, please let me know and I will add it to the next list update. The same applies if you find any mistakes or wrong info, I don't check it all out I just relay what you tell me or I pick up from posts.
1 member likes this: JohnMat
JMD Offline
Thanks for your continuing efforts to sustain this invaluable resource...
