New
Topics48,365
Posts813,372
Members9,215
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
Latest update of the Alternative Parts List is here: https://www.dropbox.com/s/uidddziz6gt10wo/Update%2013%20PDF.pdf?dl=0Update includes a more readable section on engine sensors and info about sump plug repairs (thanks Bunny). If you know of anything that can be added to the list to help other owners, please let me know. Same applies to anything you find incorrect, I don't check out everything added but accept the information I am given from other owners as true.
Posts: 3,660 Likes: 48
Posts: 3,660 Likes: 48 |
Thanks Ian
Red Leader
Posts: 360 Likes: 8
Posts: 360 Likes: 8 |
Another vote of thanks for this invaluable resource....
Posts: 130 |
Thank you, Ian! Its what gives me the confidence (here in the States) to keep motoring.
Formerly and Still '06032' 2017 M3W, 2008 Ural Patrol, 2021 Vespa 'Racing 60' Other stuff....
Posts: 6 |
Apologies, I don't see this in the list.Domeone might want to check my sleuthing.
It is part 35 in the 2012-2014 parts book. Part 22 in the 2014+ parts book 35 K130016 O.RING OIL FILTER HOUSING S&s parts: 50-4066 50-8005
HD parts: ??? Listed as a replacement part for 2 hd models in the s&s catalog but no hd part given. 11168A
Hello Divine and congratulations on your first TM post. Looking at the parts diagram, it's two O rings, one looks shaped but that will be the shape formed by the grove it sits in. I don't have any details on them but they will be standard Viton O rings. Now looking at the S&S parts book, the round O ring (item 31) is listed as size -017 and the shaped one (item 32) as size -022 but I cannot identify those numbers for sure. If you measure them up for section size and inside/outside diameter they are all available from a number of sources, such as eBay or Bearing King.
Once you know the sizes please let me know and I will add the details to the next list update. That won't help you but it will make things easier for the next person who has to change them for a leak and making M3W ownership easier is the idea.
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
Does this help? Left column has 017 and 022 specs ![[Linked Image]](http://www.tm-img.com/images/2023/07/13/IMG_6173.md.png)
Thanks for that P964 👍. Every day is a learning day, they are BS017 and BS022 Viton seals and cost about 40p each on Bearing King in the UK.
Latest update of the M3W Alternative Parts List is here: https://www.dropbox.com/scl/fi/n4vo...rlkey=ph41ye2o0at74jgqhem9erzrk&dl=0Update includes engine oil pressure sensor info, oil filter housing to crankcase seals , oil tank/crankcase alternative vent info, alternative front indicators, luggage rack suction cap. As always, if you know of anything that fits or works better for the M3W, please let me know and I will add it to the next list update. The same applies if you find any mistakes or wrong info, I don't check it all out I just relay what you tell me or I pick up from posts.
1 member likes this:
JohnMat |
Posts: 360 Likes: 8
Thanks for your continuing efforts to sustain this invaluable resource...
