10 members (John Winn, Alan Patterson, Dada, david nathan, Graham, G4FUJ, BobtheTrain, Gordon D, sewin, Rex_tulips, Elliot),
285
41
SORN
New
Topics48,367
Posts813,392
Members9,215
Posts: 2,027 Likes: 23
Posts: 2,027 Likes: 23 |
Is the problem that the OE part isn't available from whoever supplied them (Ford/Land Rover etc) or is it that we don't know what it came from?
I know what the originals were from.. I've spent the last 12 months trying to source them. They are no longer available anywhere. I have an aftermarket motor and cable solution that will be able to be fitted and will work, but its not quite a like for like fit- hence why I need a car to prototype on.... I'm not MMC- I don't just guess how parts will fit...  What were they from out of curiosity?
Aero 8 GTN #11
Posts: 336 |
when my passenger one went, snapped cable as it had corroded with lack of use, it was a Fiesta unit but I think a bespoke set of bowden cables wound on to it or modified originals. Splined Hub in Oundle did mine a few years back.
Posts: 138 Likes: 1
Posts: 138 Likes: 1 |
I'm yet another owner looking for a window motor for an Aero S1 on drivers side. Have emailed Simon of SiFab to see if he had any success?
AnDrew G 2003 Aero S1 2009 Aeromax - past
Posts: 198 Likes: 1
Posts: 198 Likes: 1 |
Let me know if you have any luck as I’m still looking for one 18 months later😁
Posts: 138 Likes: 1
Let me know if you have any luck as I’m still looking for one 18 months later😁 Will do, Simon from SiFab is still working on a replacement. Is window not working an MOT failure? Cheers
Posts: 535 Likes: 1
Posts: 535 Likes: 1 |
An electric window not working is NOT and MOT failure - just an annoyance, particularly in relation to the sound of the side exit exhausts!
Cheers, Paul
Posts: 377 |
I think when the factory replaced mine in the S1 over 5 years ago the unit was £750 !!!!
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 2,384 Likes: 56
Posts: 2,384 Likes: 56 |
Remove the plasic shroud think its four screws have a look inside if your not confident a good auto electrician the type that recon starters and altenators will fix it for you even if you buy a similar motor and switch the innards. The bowden cables can be bought at various length from any motorbike shop. If you run a series 1 you have to dig about a bit the factory is no help at all and the other guys who sell some spares wont tell you what they came off....
Posts: 12 |
Hi all ,
If you are looking for the motor only i have some used one.s that came with the car when i bought it.
Unfortunately i don' t Know where he sources there but i confirm there are original when i have repaired my mechanism!
Pm for more or pics
Regards
Posts: 1,415 |
Remove the plasic shroud think its four screws have a look inside if your not confident a good auto electrician the type that recon starters and altenators will fix it for you even if you buy a similar motor and switch the innards. The bowden cables can be bought at various length from any motorbike shop. If you run a series 1 you have to dig about a bit the factory is no help at all and the other guys who sell some spares wont tell you what they came off.... We don’t tell you what the parts are from because 90% of the time they are modified from OE And also our knowledge is hard won, I for example have 22 years experience with Morgan and if we disappear, and the factory are no hope- where does that leave you as the owners?
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
