3 members (John Winn, High Hamster, Strathaven), 179 guests, and 98 robots.
+8Rich 79
Topics49,871
Posts837,684
Rudolf
#761361 13/11/22 05:38 PM
As a matter of interest does any other old Morgan have this arrangement for the handbrake. It doesn't appear in any of the documentation I have (Original Morgan Instruction book and John Dowdeswell's Workshop Manual.)
Also I ought to replace this piece as it was cracked. My local indy welded it, and ground it to shape.
This piece fits in the box on the slave cylinder, and is pulled out by the handbrake, pushing up two pegs which force up the shoes onto the drum.
I cannot find the piece on BHM parts list nor on Mervyn Rutters website.
1956 Plus 4 4 seater
TBM Offline
It's shown in the diagram on Morgan Spares, but unfortunately doesn't seem have a part number.
Morgan Spares
Arwyn may be able to help - I think I recall a FB post where he was looking for the same.
Yes, thats the early Plus 4 set up on a 3HA axle
Was able to obtain a spare lever from Derek Willburn but I think it was the last one he had.
Derek stepped in just before I sat down with my Girling parts books and tried to cross reference it
It may be Riley RM but I'm not 100% sure of that.
Won't be an easy part to make - as its, profiled, twisted and then hardened and ground.
Could yours be welded? Not sure but I guess there are some on here who can wield a TIG torch better than me!!
Arwyn
Arwyn
Thanks Arwyn,
Yes, mine was welded. When I first acquired the car back in June I took it to my local indy, who does work on classics as well as modern. He took the drums off to check the linings and investigated the handbrake mechanism. He found the crack on one side so removed it. He has a guy who is a dab hand with TIG, so it was welded and ground back to shape.
I was advised to see if I could find a replacement, but having just fitted the relined brake shoes, and checked the hb mechanism, I couldn't determine which had been welded.
According to my Girling catalogue the brakes appear to be Type HW and this item is listed as a Draw Link part number 481845.
The mass production application was Rover 80, 90, 100, 3 Litre and 3.5 P5B.
Hope this helps
Jack
Jack
1985 4/4 T/C 4 seater Royal Ivory
1934 F Type
2018 Pembleton SuperSport (self built).
Thanks Jack,
At least I have a part number, but trying to source the item is proving a challenge. Needless to say but the current Girling parts catalogue doesn't include it.
I'm not too worried though as the repair weld is fine.
Paul at Power Track brakes has lots of NOS classic brake parts, may be worth a call
https://www.powertrackbrakes.co.uk/
