2 members (Bitsobrits, TBM), 234 guests, and 95 robots.
Topics49,847
Posts837,389
Page 10 of 16 1 2 8 9 10 11 12 15 16
Hi Richard, thanks for staying with me thumbs
Following your comments yesterday, I have two further clarification questions that I'll seperate out into two posts so they can be answered individulally.
CLARIFICATION ONE:
Not clear to me from your description but having eventually found the expected two blue/yellow wires, note they need to be joined together if not already.
When I checked the two blue/yellow wires I'd expected both to be carrying +12v with the lights on, that is one to supply current to the O/S lamp and the second one to supply the N/S lamp.
However, clearly my logical assumption was wrong, what I actually found was only one of the blue/yellow wires was live, I used it to prove I could at least power up the O/S lamp from the dash wiring but remained confused as to why the second blue/yellow wire was showing 0v on my meter confused2
So if I've understood correctly what you're saying is I need to connect these two blue/yellow wires together to create a loop as one feeds back to the dash?
And connect them together with a Lucas style 4.7mm double like this?
So I can finally run new wiring forward from the double connector to supply +12v each lamp?
CLARIFICATION TWO:
The reason is only one routes back to the dash, the other being free standing and purely provided to route the single feed to other, n/s of car. You will have to search for far end of it under that wing. A double female bullet connector works well to join wires together if some PO has removed it to add the extension. You should end up with three wires going into it on o/s.
BTW checked under my car this evening and found the unused double female bullet on o/s feeding through to a single n/s. Not easy to check colours in-situ but 99% certain they would be blue/yellow.
I believe what you're saying here is there's more blue/yellow wiring to find in the N/S wheel arch?
And once found, I need to be bring it back across the to the O/S wheel arch where I would connect it to the Lucas style 4.7mm double connector that's also now also serving to loop the two blue/yellow wires I finally found yesterday evening in the O/S wheel arch?
Or, are you saying with the loop created the blue/yellow wiring still hidden in the N/S wheel arch will become live?
Sorry for all the questions, but it's not always easy to pull clear step by step instructions out of a series of paragraphs, probably just me being thick mate laugh2
Originally Posted by Montegue
When I checked two blue/yellow wires I'd expected them to both be carrying +12v with the lights on, that is one to supply current to the O/S lamp and the second one to supply the N/S lamp.
Correct on all counts Dave thumbs although I did point this out several times in earlier posts somestick
MMC make this easy for you by providing the double female bullet which serves to isolate and protect the male ends when the wiring is not used as well as completing loop to other side. I can only assume that a PO of your car saw fit to remove and add a cable extension for whatever.
Quote
Yes the other end of loop will be found under n/s wing. No need to "bring it back" this is simply the other end of blue/yellow wire providing loop of switched +12v from o/s, so both lamps illuminate together.
Only thing not mentioned was ground connection for fog lamps each side. I would be tempted to use another double female bullet to replace single on the black lead to headlamps unless you can find unused grounds elsewhere.
Traditional foglights draw a fair amount of current and unless the wiring is already run from a relay up under the dash it might be worthwhile considering fitting a relay and picking up power from a main powered line rather than through the foglights switch.
I guess this could be avoided if the foglights themselves or the bulbs are low current LEDs.
On my car I have the front foglights set up as driving lights and the relays are set so that they can only come on when the headlights are on high beam. I had this set up after discovering that I was sometimes inadvertently blinding oncoming drivers frown
I did consider using the old trick of having one foglight and one driving light but my experience of front fog lights is that you tend to get too much light reflected back at you from the mist so I thought just having driving lights was a better idea.
Out of interest Peter since you have a similar age Plus 4 , did you use any of the MMC dedicated lamp and dash switch wiring, relays aside?
Rog Offline
Richard are those ‘plug and play’ blue/yellow wires fed from the o/s side light 7.5A fuse?
Roger
Rog #762837 29/11/22 05:24 PM
The wiring is essentially plug and play and the power does come from the sidelight circuit (red/orange wire) but via three fuses since the sidelight switch itself is fed by fuse 18 15A, then you have the 20 A fusebox fuse confused2. The blue/yellow wires are only live when the switch is added and turned on.
I see why you asked though so yes it would be a good idea for Dave to up the o/s sidelight fuse 12 from 7.5 to 15 amp OR fit LED equivalent bulbs in his fogs.
Quote
Awesome Richard, and apologies for my short term mammary loss, I feel less of a tit now somestick
[I see why you asked though so yes it would be a good idea for Dave to up the o/s sidelight fuse 12 from 7.5 to 15 amp OR fit LED equivalent bulbs in his fogs.
Gotch-ya thumbs
Best to avoid this exting
I take your point about sharing the ground with the headlight, this is my current solution... no pun intended laugh2
Monty has lovely drivability, I wouldn't want to introduce anything that could interfere with that.
Slightly off topic but in the course of this thread I've referred many times to the wiring schematics published in the 2006 - 2014 Classics parts book available for download here. There are three iterations of the Plus 4 and V6 chassis loom shown but I've spotted an error related to fuse box labelling in the latest one dated 2007, relevant part as below.
The 20 position fuse box is labelled correctly running down the r/h side 1 - 10 but reversed on the l/h side. It should read fuse 11 - 20 running down l/h side to concur with fuse ident listing (not shown but to the right in full schematic) and associated cables/circuits.
