0 members (),
380
32
Topics49,915
Posts838,214
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
I didn't want to pull a thread drift on the Roadster badge post so ..... when I fitted the louvered panel onto my Roadster Sport I had to remove the central wings on the rear panel first. It seems that whoever fitted it originally had a couple of goes before they got it right, I guess they never thought it would be discovered: bit of a mess quite frankly but hey ho.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
The cowl badge on my 2012 was the same. One hole, and one "elongated" hole.
But the biggy with trads is where the two fasteners hold the grille to the base of the cowl. My Roadster was properly assembled with Rivnuts in the lower panel.
My 2012 was a total dogs breakfast with both holes massively elongated, and by then no Rivnuts. My 2016 was probably even worse.
Posts: 5,608 Likes: 617
Posts: 5,608 Likes: 617 |
I didn't want to pull a thread drift on the Roadster badge post so ...... Are you sure you're a genuine member of this forum and not some imposter!!? ... doesn't sound right to me! 😁 K
K Ta very much. Guilty as charged
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
I didn't want to pull a thread drift on the Roadster badge post so ...... Are you sure you're a genuine member of this forum and not some imposter!!? ... doesn't sound right to me! 😁 K Does seem a bit fishy ....
