6 members (DCH, JohnHarris, CooperMan, Farmershands, Graham, G4FUJ, TBM),
362
68
Posts837,254
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Has anyone replaced the oil pressure switch? If so, can you identify what type it is exactly please? I suspect it is a Harley Davidson item from an early 2000's model, such as a BC31534-T but it would be good to know which is the correct one.
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
S&S 106-0744 ![[Linked Image]](https://www.tm-img.com/images/2022/12/09/Screenshot-2022-12-09-at-14.09.24.png) Looks the same to me as any number of Harley ones. ![[Linked Image]](https://www.tm-img.com/images/2022/12/09/Screenshot-2022-12-09-at-14.14.23.png) If it was me (and to be on the safe side) I'd go with one specifically for a 'Big Twin' but they may actually all be the same spec?
Andy
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Isn't it just a switch that senses pressure, not a specific pressure?
I would have thought it must have a trigger pressure at a specific level but that must be pretty low, so you could be right Lightspeed. I know that mine never comes on with the engine running, even when the oil is very hot and at idle with a pressure indication of 22 psi on the SPA gauge.
It isn't my cars switch that has failed but I was asked by another owner if I knew which switch it is and I don't know the exact Harley equivalent to the S&S item. The S&S 106-0744 is only $21 (if you can get one) or £46 from Morgan! The HD items are more readily available at a more reasonable price, the main reason for the Alternative Parts List.
Dab of Oppo changed one so may know a specific part number?
Andy
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I will go through my file and get the number tomorrow.
Oil pressure switch is made by Accel, part number 505330
Fits 77-22 XL; 08-12(NU)XR1200
Thanks for that info Dab of oppo. That number converts to an OEM Harley p/n 26554-77A, which is readily available from several sources at reasonable prices, always good to know. It will be on the next list.
