3 members (yobtaf, Jo S, Mauli),
268
35
Topics48,341
Posts812,981
Posts: 7,894 Likes: 241
Posts: 7,894 Likes: 241 |
[img] https://imgur.com/a/YOSc0lx[/img] Hi If this image does not come up then I need REAL HELP! Somebody sort this out for me! This is our2019 P6 radiator and as you can see it has failed where the tube goes into the top tank. Kerry Kerry, looks like the actual pipe has a radial crack, as opposed to a failed weld - quite unusual Hopefully Simon of SiFab will comment with a proper tech view ?
Posts: 612 Likes: 13
Posts: 612 Likes: 13 |
![[Linked Image]](https://tm-img.com/images/2022/08/24/20220824_132355.jpg) The white line was the leak on my radiator
Posts: 327 |
Why is it that rads are always a problem. Back in 2008 I had a couple of replacements for a new Caterham i had at the time, i eventually bought a Pro Alloy rad and never looked back. My 2011 Plus 4 radiator expired at 3 years old, usual issue, leakage at the header tank / core crimped joint. Installed the Mulfab kit, problem solved, still going strong. Pro Alloy manufacture some great ali rads etc. My pal has just took delivery of an ali rad for his C-Type Jaguar, it too nice to install in the car.
Posts: 11,220 Likes: 159
Posts: 11,220 Likes: 159 |
It's a space shuttle moment. You need to make your device as cheaply as possible but within a defined standard of quality. People often underestimate basics.
Posts: 7 |
2022 Plus Four auto, had new radiator and swirl pot in September; started leaking A LOT today.
Like Simon above, I'm suspicious of the swirl pot's ability to fix what appears to be a fundamental mounting issue.
Ho hum. Time to get those wings off again...
Posts: 957 Likes: 1
Posts: 957 Likes: 1 |
Ho hum. Time to get those wings off again... This really is not great! A radiator fitted in September (obviously few miles since) should not then fail again..... I think I would be asking for a replacement vehicle and rejecting the car? I could put up with a few niggles (I accept it is a Morgan i.e., hand built, low volume car) but a decent radiator IS a fundament that needs to be 100%?
2004 Roadster S1 3.0 V6 gone!
Mark
Posts: 7,058 Likes: 20
Posts: 7,058 Likes: 20 |
Ho hum. Time to get those wings off again... Not good, sorry to hear that news....
Ho hum. Time to get those wings off again... This really is not great! A radiator fitted in September (obviously few miles since) should not then fail again..... I think I would be asking for a replacement vehicle and rejecting the car?I could put up with a few niggles (I accept it is a Morgan i.e., hand built, low volume car) but a decent radiator IS a fundament that needs to be 100%? Understandable
Posts: 468 Likes: 52
Posts: 468 Likes: 52 |
Ho hum. Time to get those wings off again... It would be intersting to hear if its the actual radiator that has failed again or an associated fitting or hose.
Posts: 957 Likes: 1
Ho hum. Time to get those wings off again... It would be intersting to hear if its the actual radiator that has failed again or an associated fitting or hose. Dave, looking at previous images within this thread, they have shown it is the radiator.
Mark
