9 members (nick w, +8Rich, vbalddave, James B W, IcePack, CooperMan, John V6, Mr.Tennant, RichardV6), 313 guests, and 35 robots.
Adam12 69
+8Rich 67
John V6 61
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,368
Posts813,420
Members9,215
Rbt Aero8, Salmon, stevends
FrankW Offline OP
Hi Folks,
my 2019 Roadster shows around 2-3 cm less ground clearance on the driver side compared to the passenger side. It has around 10k miles on the clock. It has been driven mostly without passenger. Could it be that the 5 link spring/ damper on the driver side has softened over the years? Would this be solved by fitting the SSL units? I wanted to do this anyway having read all the positive reviews. But before I do this I wanted to find out if anybody has seen a similar "leaning" to the driver side and also to understand where it comes from.
Best regards,
Frank
Online NoMood
Totally normal to have some clearance reduction on drivers side I understand Frank, particularly if you drive regularly without passenger. I can however recommend the SSL front and rear kits. I was lucky to have the prototype SSL 5 link dual rate rear kit fitted (in a matter of minutes) and noticed the improvement in both ride and roll resistance in very short order. I was apparently their first customer to sort the rear suspension before front and quickly realised I also needed the dual rate treatment with their front RS kit to compliment.
Still very happy after close to 15,000 miles. Have had one front settling in check since fitting, finding I had to increase the drivers side pre-load a few mm more to gain the zero static pre-load on each rebound spring. Never thought to touch the rears other than adding a little damping when touring two up. No reason the adjustable spring platform couldn't be tweaked to even ride height though if it's an issue.
FrankW Offline OP
thanks, Richard, I will go for SSL front and rear now.
E
E
On my 2006 Plus 4 I had a significant list to drivers side. I drive a lot solo but even with wife there is a 7 stone variation between Starboard and Port. 2 years ago Williams fitted two new leaf springs BUT I had the drivers side spring loaded for our circumstance. The spring was heated and fettled. The car is now spot on empty, solo and with both of us onboard. Best money I spent.
Online NoMood
Bear in mind it can be difficult to find the static ride height at the front particularly if you have the wider front tyres as on your Roadster. Reason is the stub axle angle is greater than 90° and as they slide up the laterally inclined kingpin there is a tendency for tyres to pinch together. Wider tyres resist this more causing car to not fully settle on springs when stationary unless moved back and forwards a tad.
Oh and a belated welcome to TM Frank wink
Hi Folks,
Best regards,
Frank
I have the same setup as Richard on a 5 link Roadster, and agree with his comments
You could try an easy test & just swop over o/s to n/s on the existing rear coilovers as they are easy to access
FrankW Offline OP
thanks for welcome, Richard :-)
Jon, what exactly is o/s and n/s?
Off side and near side.
2025 MG ZS EV aka Trigger
FrankW Offline OP
ok. that means replacing the original shock absorbers with the SSL Roadster springs is a job I could do myself or would you recommend to have this done by a dealer? It looks like two nuts and bolts per side. But maybe it is more involved
I think the first advice is to stop the shocks from side to side. I'll let someone else comment on how to do it on a 5 link set up
