0 members (),
287
38
SORN
New
Topics48,368
Posts813,421
Members9,215
Posts: 62 |
Hi All, Hoping someone can help - the 68 +4 (4 seater) tacho cable - is it a morgan specific product or is it a TR4 product? Caught in a non deliery situation and need to find an alternate solution? Many thanks for everyones contributions! L
Posts: 35,796 Likes: 474
Posts: 35,796 Likes: 474 |
This might be a start - you don't say where you are. Good luck.
Posts: 1,148 Likes: 18
Posts: 1,148 Likes: 18 |
The tacho cable fits into the gearbox and routes under the drivers seat and is a Morgan specific
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 62 |
Isn't that the speedo? Tacho from guage below the distributor?
Yes that is the speedo cable, agree rev counter goes through to distributor drive
Posts: 1,578 Likes: 105
Posts: 1,578 Likes: 105 |
Terry Foxen at GEE has them on the shelf.
Believe it or not the speedo and tacho cables are the same length and are interchangeable
I know...I just fitted one of his last night to my 1968 Plus 4 4 seater!
Make sure you lubricate it with powdered graphite before fitting and keep the cable bends as gentle as possible and you'll be fine
Arwyn
Posts: 350 |
It may matter whether your Morgan is LHD or RHD, since the gauges are switched. I have a 1961 +4 four-seat and a TR4, both are LHD. The LHD TR4 cable looks too short for the Morgan, but a RHD TR4 cable might be longer. Since the Morgan and TR4 tach gauges are interchangeable, a RHD TR4 cable should work on a LHD Morgan +4 if it is long enough.
1961 +4 Four seater
"Crude, but effective."
It may matter whether your Morgan is LHD or RHD, since the gauges are switched. I have a 1961 +4 four-seat and a TR4, both are LHD. The LHD TR4 cable looks too short for the Morgan, but a RHD TR4 cable might be longer. Since the Morgan and TR4 tach gauges are interchangeable, a RHD TR4 cable should work on a LHD Morgan +4 if it is long enough. Interchangable but there are subtle differences between the two guages! Arwyn
