11 members (Nickplus4, sewin, linklaw, hugo, TalkMorgan, RichB, Rex_tulips, Zach, RichardV6, RedThree, DaveK), 299 guests, and 39 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,332
Members9,215
For Sale,
1700cc Ford cross flow engine taken from my race car.
120 BHP @ flywheel, nice idle, great for road or track.
Spec as follows,
Ford 711M block
Steel front pully
Lightweight flywheel (5kgs less than standard)
AP Racing clutch
Fuel pump blanking plate
PCV breather valve removed
High pressure, high flow oil pump
+ 90 thow pistons
Piper 285 camshaft
Steel rocker posts
Steel rocker spacers (replace springs)
Alloy rocker cover
Ported head with increased valve size (Specalized Engines stage 3)
Unleaded valve seats
Aldon distributor
Duplex adjustable timing pully
Duplex timing chain
Oil cooler sandwich plate
New water pump
Race head gasket
Librands exhaust manifold
82 degree thermostat
Silicone breather pipes
Fully balanced con rods, pistions, crankshaft, flywheel, clutch and front pully
Supplied with twin Weber 40 DCOE carbs, set up on rolling road for this engine, (no throttle linkage).
Inlet manifold.
Angle plate to lift carbs over wing so no modification to the wing is required.
Webcon air filter gauzes Altenator and belt
Sandwich plate between gearbox and engine
Only run for 12 races, only run on Millers race oil £60+ a gallon, and changed every 3 races.
Only reason for sale is I'm swapping to a Zetec for next season.
Grab a bargin, this would cost 3 times asking price to build.
£1800
up to the top ^^^^^^
Hi Jim,
Could do with a freshen up then after 12 events?
Any flexibility on price?
Thanks
Steve you have a PM
Still for sale
Christmas prezzie for your slow 4/4?
NOW SOLD
Has it gone to another SpeedMogger Jim?
Cheers,
'09 Gen2 MINI Cooper ragtop
