Topics49,868
Posts837,638
Posts: 103 |
The battery on my 1994 plus 4 has decided enough is enough and I need a new one. There’s no labels I can see on the old to match it up so I called into a major auto retailer this am. They were unable to find one either via the registration or model so could offer nothing! Anybody any idea which what it could be before I have to take it to some motor factors and try to match it up based solely on the physical dimensions?
Tony
1994 Connaught Green Plus 4
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
On my 93 +4 I have an Exide Excell EB450 45Ah 330
You may have to remove the carrying handle with a hacksaw to fit the clamp.
Hope that helps, John k
1993 T16 +4 Lancia Blue.
Paste
into Ebay
£69.99
Posts: 8,683 Likes: 413
Posts: 8,683 Likes: 413 |
If I were in the market for a new battery for my Mog I would be looking at this generic type 075 one. Double check size for your car though on link below. ![[Linked Image]](https://cdn.shopify.com/s/files/1/0084/9369/5035/products/56077_1080x.jpg) Highly recommend the brand. Great value for money.
Posts: 8,682 Likes: 493
Posts: 8,682 Likes: 493 |
I fitted a Varta D59 for a pal last year, no mods required, dropped straight into the frame
I fitted a Varta D59 for a pal last year, no mods required, dropped straight into the frame Yes that's a generic type 075 as well with same 60AH capacity
Posts: 103 |
Thanks guys. At least I’ve something to search for
Tony
Thanks guys. At least I’ve something to search for Yes any type 075 should fit assuming there have been no changes since 1994. I do find that quoted measurements vary a mm or two within generic types but there is usually enough leeway to accomodate. Important thing in terms of longevity is buying largest capacity that will fit. Here your bottom line is 60 amp hour, CCA less important.
