7 members (Alistair, JohnHarris, Themorganeer, jbk, RichardV6, Gordon D, bmgermany),
213
47
Topics49,844
Posts837,354
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
The steel pipe is completely simple, IDxOD 35x25mm, as long as you can push inside... The Morgan rectifier went wrong first, then I had a Harley, that went wrong too. Now I put a small from motorcycle Suzuki, we'll see how long it lasts... :-) keep the tips coming andrej m3w
Posts: 1,562 |
Inspired work Andrej, great ideas and well executed. Do you have any more photos as you were doing this work to help inspire others, especially the chassis tube reinforcement front and rear, and the engine mounts? Looking forward to hearing about your bevel box ideas. Keep up the good work.
Posts: 4 |
Andréj hello, your article on strengthening your framework is very interesting. I plan to do it on my 3 Wheeler from May 2012. It has a lot of vibrations and on French roads which deteriorate it becomes problematic. I have many qustions : Where did you place the reinforcements in the tubes? What is the diameter of the reinforcement tubes? How thick are these reinforcement tubes? How did you manage to push in the tubes? Did you use lube? Did you weld them to the chassis? If so at what levels? Did you have to disassemble the engine? Have you been forced to undo welds? Have you treated the inside of the tubes against rust? Concerning the new mounts for the silentblocs, did you make new mounts or modify the old ones? Do you have plans for these supports? If you have other photographs, I'm interested. I thank you for your collaboration. Sincerely Marc Joulin.
Posts: 36 |
Hi Marc, during weekend I will prepare some pictures and answer your questions :-)
Posts: 718 Likes: 11
Posts: 718 Likes: 11 |
Andréj hello, your article on strengthening your framework is very interesting. I plan to do it on my 3 Wheeler from May 2012. It has a lot of vibrations and on French roads which deteriorate it becomes problematic. I have many qustions : Where did you place the reinforcements in the tubes? What is the diameter of the reinforcement tubes? How thick are these reinforcement tubes? How did you manage to push in the tubes? Did you use lube? Did you weld them to the chassis? If so at what levels? Did you have to disassemble the engine? Have you been forced to undo welds? Have you treated the inside of the tubes against rust? Concerning the new mounts for the silentblocs, did you make new mounts or modify the old ones? Do you have plans for these supports? If you have other photographs, I'm interested. I thank you for your collaboration. Sincerely Marc Joulin. +1
Posts: 4 |
Je vous remercie Andréj. Désolé je ne parle pas Anglais, mais le traducteur vas m'aider. Bon courage. Marc
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Où habites-tu Forum français https://clubmtw.forum-box.com/t1289-Super-3.htm
Posts: 4 |
Bonjour, je suis du Maine-et-Loire. J'habite à 20 minutes d'Angers
Another option ![[Linked Image]](http://img115.xooimage.com/files/c/a/7/54a1234a-b5f9-48...1ebdb56-5958c23.jpeg)
Your option andrej seems to be easy to be done
