3 members (DaveW, DCH, mph),
289
49
Topics49,844
Posts837,357
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Craig Jezz
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
Me neither. I can live without.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
I wasn't too fussed when the current Roadster had them as standard, but they are very useful when working on stuff in the footwell
I wasn't too fussed when the current Roadster had them as standard, but they are very useful when working on stuff in the footwell Same Jon, they were already fitted to my 4/4.
Craig Jezz
Posts: 22,357 Likes: 353
Posts: 22,357 Likes: 353 |
Ahhhhh! Thanks.  You mean you don't have footwell lighting, Dave??  No, Alan. Not sure they were available in 2005 on my Roadster. When we ordered our GDI in 2016, I had to remove a few things from my wish list, because the price was going loopy loo. I don't remember if footwell lights made the semi final cut. I had to delete yellow stitching, carpet edging and embroidered head restraints. I also deleted the build book, but put it back on at the last minute. I didn't think it was fair to be living at the factory taking pics and not ordering the official build book!
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
I only had this footwell light on one of 5 Morgan. It was the 2010 Roadster Sport. I couldn't custom order anything on that car anyway except for a colour and the colour of the interior.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
My 4/4 has a flexible map light, which is almost as good.
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
My 4/4 has a flexible map light, which is almost as good. Mine too.
Posts: 28 |
I had the same problem with the heater control on my 2013 4/4. I suspect it was due to the dealer not refitting the dashboard properly after installing the power steering. I had a very chilly trip back from my niece's wedding with the top down! Getting the hard wire fitted can be tricky (and dropping bits is a buggeration!) NB. WD40 s a Water Displacement treatment not a lubricant: it will dry to a varnish very quickly. Use a good oil to ease parts
I had the same problem with the heater control on my 2013 4/4. I suspect it was due to the dealer not refitting the dashboard properly after installing the power steering. I had a very chilly trip back from my niece's wedding with the top down! Getting the hard wire fitted can be tricky (and dropping bits is a buggeration!) NB. WD40 s a Water Displacement treatment not a lubricant: it will dry to a varnish very quickly. Use a good oil to ease parts  I used the WD40 High Performance Silicone spray which is also a Lubricant, then i applied grease when it worked free.
Craig Jezz
