1 members (Montegue),
367
47
Posts837,277
Posts: 2,049 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,049 Likes: 12 |
Fellas
Anyone specced the heater???
Is it effective??
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 100 Likes: 2
Posts: 100 Likes: 2 |
Fellas
Is it effective?? I did. And it does nothing. Blows a bit of cold air and makes a racket. I wouldn’t bother.
Fellas
Is it effective?? I did. And it does nothing. Blows a bit of cold air and makes a racket. I wouldn’t bother. Ah ok. Many thanks
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Just a quick warning to any new Super 3 owners, protect your front axle with some anti-corrosion spray!
I’ve done 500 miles in my Super 3 and it’s already started to rust. I said to the dealership and they said this happens if you plan to drive the car in winter. They recommended I use ACF50 spray. I’ll be honest, I wasn’t expecting to have the rattle can spray paint out on my brand new £50k car.
Here’s some pictures. They don’t really do it justice, looks a lot worse in person.
Amazing that a Morgan Dealer would say that. Such poor quality for so much money....
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
I use Chlorinated Rubber paint (don't let the rubber bit put you off) on parts that are going to get some abuse, it's very, very tough and durable
Posts: 149 Likes: 4
Posts: 149 Likes: 4 |
Fellas
Is it effective?? At first I thought it wasn't until I did a bit of amateur contortionism and had a good look in the footwells to locate the vents - the drivers vent was shut and the passenger one was pointing too high. Once I opened/adjusted them it did make a difference at lower speeds. At higher speeds even with the tonneau over the passenger side the amount of wind coming into the cockpit overcomes any heat. Chris2002tii is right, the higher speed setting is louder than the engine though...!
Heron Grey & Typhoon British Green Super 3 SOLD Plus 6, Silver and tan.
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
Fellas
Is it effective?? At first I thought it wasn't until I did a bit of amateur contortionism and had a good look in the footwells to locate the vents - the drivers vent was shut and the passenger one was pointing too high. Once I opened/adjusted them it did make a difference at lower speeds. At higher speeds even with the tonneau over the passenger side the amount of wind coming into the cockpit overcomes any heat. Chris2002tii is right, the higher speed setting is louder than the engine though...! Don't feel too bad about the noise. Last week I was a passenger in my friend's hugely expensive all electric Mercedes. Expecting a quiet drive I was amused to find that the only way to keep the windscreen demisted was to have the fan on and the fan made a massive noise, far louder than an engine. Also a message announcing something not available superimposed itself across the sppedometer display blocking sight of the speed. It was one of those computer boxes with a tiny X in the top corner to exit it. The only way to hit this X was to put his hand through the steering wheel! And several seconds not looking at the road. There was also a fake rev counter.... Also, he told me that the auto headlight dipping is so slow that everyone flashes him at night.
Posts: 33 |
Random question - those who have taken delivery do you know the dimensions of the spotlights? Any model name or part number on the cibie unit?
Super 3
Posts: 149 Likes: 4
Random question - those who have taken delivery do you know the dimensions of the spotlights? Any model name or part number on the cibie unit? I might be wrong but I think they are these ones: https://www.demon-tweeks.com/uk/cibie-mini-oscar-led-lamp-990409/Cibie Mini Oscar LED Lamp 130mm diameter Cibie product code 45300 (I think)
Posts: 33 |
Thanks - thats helpful. Although I think they are the 145 mm version
Super 3
