Topics49,911
Posts838,146
Posts: 148 |
Could someone please help me with a photograph of how to change the oil in my 2009 Roadster differential, Thank you
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6 Audi A4 Advant (some blue colour not botherd)
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
See Dave Ws how to section under Roadster service. Roadster Sevice
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Isn't it just a matter of removing filler and drain plugs in that order, ideally after a good run to warm oil. On my axle the filler plug required a hex key and drain plug required a socket for hex head. Obviously have a tray underneath to catch oil with minimum 2 litres capacity.
I leave mine to drain fully maybe even overnight, then replace drain plug and refill with recommended oil through filler plug until it just starts to gently dribble out of plug hole, then replace. Access from above after removing tool tray can help.
For reference the BTR axle on my Roadster took 1.6 litres.
Posts: 148 |
Thank you both, your help is really appreciated
Recommend one of these for re-filling gearbox and diff. ![[Linked Image]](https://i.ebayimg.com/images/g/tv4AAOSwhqhaDp9u/s-l1600.jpg) Click for source.
Posts: 148 |
Thank you RichardV6 , took your advice and got one from ebay
Posts: 148 |
Just one last question. In the manual it says to use 80/140 oil but they only one I can get is 75/140 , will this be ok to use?
Posts: 412 Likes: 10
Posts: 412 Likes: 10 |
2009 4/4 Sport in Red 2022 Harley Davidson FXLRS Low Rider S 1977 Triumph Stag
Ditto my diff on the S1 & the 3.7 were / are fine. Allon White also filled the S1 diff with this oil
