Topics48,346
Posts813,060
Posts: 143 |
Could someone please help me with a photograph of how to change the oil in my 2009 Roadster differential, Thank you
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6 Audi A4 Advant (some blue colour not botherd)
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
See Dave Ws how to section under Roadster service. Roadster Sevice
Posts: 7,924 Likes: 217
Posts: 7,924 Likes: 217 |
Isn't it just a matter of removing filler and drain plugs in that order, ideally after a good run to warm oil. On my axle the filler plug required a hex key and drain plug required a socket for hex head. Obviously have a tray underneath to catch oil with minimum 2 litres capacity.
I leave mine to drain fully maybe even overnight, then replace drain plug and refill with recommended oil through filler plug until it just starts to gently dribble out of plug hole, then replace. Access from above after removing tool tray can help.
For reference the BTR axle on my Roadster took 1.6 litres.
Posts: 143 |
Thank you both, your help is really appreciated
Recommend one of these for re-filling gearbox and diff. ![[Linked Image]](https://i.ebayimg.com/images/g/tv4AAOSwhqhaDp9u/s-l1600.jpg) Click for source.
Posts: 143 |
Thank you RichardV6 , took your advice and got one from ebay
Posts: 143 |
Just one last question. In the manual it says to use 80/140 oil but they only one I can get is 75/140 , will this be ok to use?
Posts: 363 Likes: 7
Posts: 363 Likes: 7 |
2009 4/4 Sport in Red 2022 Harley Davidson FXLRS Low Rider S 1974 Honda CB450K7
Ditto my diff on the S1 & the 3.7 were / are fine. Allon White also filled the S1 diff with this oil
