1 members (ChrisConvertible),
212
32
Topics49,841
Posts837,323
Posts: 472 Likes: 70
Posts: 472 Likes: 70 |
Nothing quite so elaborate as building a new exhaust system. With the seats out being reupholstered I took the opportunity to remove the handbrake as it has been a bit iffy. Although the pawl and quadrant don't look too bad I shall replace them as a precaution. ![[Linked Image]](https://tm-img.com/images/2023/01/25/Hanbrake.jpeg)
1956 Plus 4 4 seater
Posts: 32 Likes: 3
Posts: 32 Likes: 3 |
Done 1st colour covering of Renovo mohair roof covering today after the cleaner stage at weekend. The colour one needs careful application. A few drips and spills down one window and mad panic. All sorted and looking good.
Roadster V6 3.0L 2005
Posts: 3,847 Likes: 399
Posts: 3,847 Likes: 399 |
Done 1st colour covering of Renovo mohair roof covering today after the cleaner stage at weekend. The colour one needs careful application. A few drips and spills down one window and mad panic. All sorted and looking good. When treating / spraying a hood, I tend to use cling film on all the windows and exposed metal work in case of any overspray, spills or drips. Pretty easy to apply and remove.
22 Plus Four KIMI 12 Plus 4 Sport OZZY 08 Roadster FELIX 06 4/4 70th LOKI 77 4/4 SEAMUS 85 4/4 MOLLY
Posts: 27,804 Likes: 749
Posts: 27,804 Likes: 749 |
My black Neverflex hood & tonneau are getting a coat of proofer today as it is dry.
Well it went well the sun was shining so the beading, hinges etc were oiled, bonnet tape got the candle wax treatment, tyre pressures checked & a spanner / screwdriver check as well.
Very soothing after the crap weather. Hoping for a run out shortly once the salty roads dry.
Posts: 201 Likes: 8
Posts: 201 Likes: 8 |
Polished the brake stabiliser bars, removed and painted the front bumper mounting bars, cleaned up the king pins c/ springs and regreased, cleaned the front brakes, took the rear drums off and cleaned and checked the brakes, I’ve got the control technique coming up!
Mike H Bourgogne Franche Comté
Nothing quite so elaborate as building a new exhaust system. With the seats out being reupholstered I took the opportunity to remove the handbrake as it has been a bit iffy. Although the pawl and quadrant don't look too bad I shall replace them as a precaution. ![[Linked Image]](https://tm-img.com/images/2023/01/25/Hanbrake.jpeg) Does anybody know whether the thread on the rod is UNF or BSF? One of the threads is slightly damaged so I need to run a die down it.
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Thread is 1/4 BSF
Whilst you are at it drill/tap the thimble at 90 degrees to the rod to take a small (I.e 4mm or less) grub screw.
The purpose of this is to stop the thimble coming loose, usually when you don't want it to, leaving you with no handbrake!
Arwyn
Thanks Arwyn, Thought it probably was but didn't want to get a die until I was sure. Unfortunately I don't have the facility to drill/tap the thimble. I'll find another way to secure it.
Posts: 28,892 Likes: 350
Posts: 28,892 Likes: 350 |
, I’ve got the control technique coming up! Hope that goes well Mike!
