9 members (+8Rich, SEG, rossocorsa, bmgermany, MartO, JohnHarris, flyfisher, High Hamster, John Winn), 230 guests, and 32 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,047
#767746 25/01/23 07:04 PM
stumog Offline OP
Could someone please help me with a photograph of how to change the oil in my 2009 Roadster differential, Thank you
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6
Audi A4 Advant (some blue colour not botherd)
See Dave Ws how to section under Roadster service. Roadster Sevice
Isn't it just a matter of removing filler and drain plugs in that order, ideally after a good run to warm oil. On my axle the filler plug required a hex key and drain plug required a socket for hex head. Obviously have a tray underneath to catch oil with minimum 2 litres capacity.
I leave mine to drain fully maybe even overnight, then replace drain plug and refill with recommended oil through filler plug until it just starts to gently dribble out of plug hole, then replace. Access from above after removing tool tray can help.
For reference the BTR axle on my Roadster took 1.6 litres.
stumog Offline OP
Thank you both, your help is really appreciated
Recommend one of these for re-filling gearbox and diff.
Click for source.
stumog Offline OP
Thank you RichardV6 , took your advice and got one from ebay
stumog Offline OP
Just one last question. In the manual it says to use 80/140 oil but they only one I can get is 75/140 , will this be ok to use?
I use this....
https://www.morrislubricants.co.uk/products/auto/gear-transmission-oils/lodexol-xfs-80w-140.html
It has LSD friction modifier already added, although sometimes a bit more is needed if you can hear the chatter.
Opie oils do 80 / 140 an they deliver really quickly
https://www.opieoils.co.uk/c-677-80w-140-gear-oil.aspx
2009 4/4 Sport in Red
2022 Harley Davidson FXLRS Low Rider S
1977 Triumph Stag
Originally Posted by DaveW
I use this....
Ditto my diff on the S1 & the 3.7 were / are fine. Allon White also filled the S1 diff with this oil
