7 members (+8Rich, Bishmog, BobtheTrain, DaveW, Clipper, High Hamster, Michael H),
303
Topics48,347
Posts813,074
Posts: 32 |
Ginmoggie does you car have a batten under the front edge of the drivers seat to lift it a little? This improves comfort & is easy to do. If long of leg a steering wheel spacer is worthwhile. Thanks for the tip - the car doesn't currently have a batten as you describe so I'll see how I get on first then if needed make the modification. Cheers.
2017 M3W
Posts: 32 |
Ginmoggie does you car have a batten under the front edge of the drivers seat to lift it a little? This improves comfort & is easy to do. If long of leg a steering wheel spacer is worthwhile. Thanks for the tip - the car doesn't currently have a batten as you describe so I'll see how I get on first then if needed make the modification. Cheers. Nice vintage style luggage box. May not be practical on high speed long journeys but definitely has a genuine nice look at short journeys.
Any idea where I can source one please?
A Thank you,it does look pretty useful and has a hole at the bottom to give access to the fuel cap. I believe the previous owner had it bespoke made.
2017 M3W
Posts: 20 Likes: 2
Posts: 20 Likes: 2 |
Car on SORN don't forget to change oil? What is this all about or am I missing something!
Posts: 1,613 Likes: 22
Posts: 1,613 Likes: 22 |
Car on SORN don't forget to change oil? What is this all about or am I missing something! It’s not change the oil, but drain the oil from the sump. On some M3W’s oil can seep past the non return valve into the sump, on start up the oil is then spewed out of the air filter all down the front of the engine. So it is recommended until you know your engine to drain the oil from the engine and put it back in the tank when the car has sat for a long period.
Posts: 20 Likes: 2
Oh I see. Thank you for the info and your reply.
Posts: 2,396 Likes: 14
Posts: 2,396 Likes: 14 |
Hi Vitaloni, Oil from the header tank slowly seeps into the engine causing 'wet sumping', if your car has been standing awhile drain the oil out of the sump and simply pour it back into the header tank. The oil level in the tank will give you a clue. Foolishly I tried to start the car after Covid lockdown, it had wet sumped and blew the rear crank oil seal, engine out job and ££££
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Hi again Ginmoggie! Mine is Chassis no 003, originally the prototype later modified by the Factory to 'The Grim Reaper'. Google it (!) but also see it in its original form on YouTube when Jay Leno drives it. There is a M3W in St.Asaph and another in Bodelwyddan but I have no details of either cars or owners, also another owner of 4/5 or 6 'proper' 3 wheelers near Holywell, almost enough owners locally to start a Club!
Posts: 7,061 Likes: 20
Posts: 7,061 Likes: 20 |
Welcome Ginmoggie
Posts: 1,562 |
Every few weeks during a layover, to help reduce the chances of a wet sump start I detach the plug leads and start the engine for 5 / 10 secs. Obviously, it doesn't start but the oil pump recovers any oil from the sump back to the tank. This also exercises the battery, which is on an intelligent battery tender.
Posts: 434 Likes: 5
Posts: 434 Likes: 5 |
Welcome. This is a really nice car. I beleive that the sale included a bottle of gin from the distillery. My recommendation is to enjoy both, but not at the same time! Remember, "G&T" does not mean "Gine & Three Wheels".  Enjoy your new toy!
Craig - Texas, USA 2021 M3W
