2 members (DaveK, MOGDave), 256 guests, and 43 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
#768663 05/02/23 09:38 AM
M3W55 Offline OP
My Roadster is only taken out for brief runs every two or three weeks in winter. In the last week, it has started regularly to cut out for a couple of seconds before regaining power and running smoothly again. Fuel pump on the way out? Blocked injector?
M3W55 #768666 05/02/23 09:51 AM
Or fuel pump relay? Easy swap to check.
M3W55 #768688 05/02/23 12:56 PM
The fuel pump relay also powers the ECU on S1 Roadsters which I found out the hard way.
On my 3.7l Roadster the fuel pump relay was an issue. Dirt cheap to replace.
If you have 3.7l car try pressing down the relays. If they move that could be the cause, in Belle's case they seems to vibrate loose so they are taped down.
The AC relay can be used as a spare.
M3W55 #768699 05/02/23 02:40 PM
Have the same problem with a '94 Plus 8, 3.9.
My problem is not the fuel pump, as it is brand new.
Can you tell me where to find this relay.
Is it a standard 30Amp (or so) 4 or 5 blade automotive relay?
TIA
Tom
M3W55 #768704 05/02/23 03:31 PM
Look under the dash on the UK drivers side , your passenger side.
Look here on eary cars
Dave's guide Relays
Onnewer ones they are on the fuse box on the UK drivers side
M3W55 #768712 05/02/23 05:13 PM
M3W55 Offline OP
Thank you all. It is off to B+C shortly to have some body work done, thanks to a Spanish lorry driver, so we may as well ask them to check the relay while it is there.
