Topics49,849
Posts837,425
Posts: 5,439 Likes: 467
Posts: 5,439 Likes: 467 |
I became frustrated to read of a brake Modern (ish) Morgan brake light issue that seemingly required two or more dealerships to resolve what seemed like comms issues in the Mogs interfaces...! Some time back My good lady`s JLR Evoque threw a digital fit and the advice was not to drive it thus it had to be flat bedded home, the earliest it could be booked in to JLR was THREE WEEKS....after which it was picked up by another flat bed to take it to the dealership...The fault was found to be the front O/S front wheel speed sensor Cost £480. Breakdown insurance covered the flat costs bed both ways two ten mile trips on the flat bed would have otherwise been added to the £480 bill. The other day a similar situation arose AEB not available HDC not available Stability control not available Forward alert not available Handbrake also reported a malfunction ABS fault And to finish off check engine light !!! Phoned JLR local agent from where we bought the car and who repaired it last time, they said it would be SEVEN WEEKS before they could book it in...!!! Took it to a friend who runs a garage and has an expensive professional scanner that he pays a monthly fee for to include updates for all makes and models. It identified the N/S front wheel sensor, which I fitted..... All alarms cleared after a few yards drive.... Job done Sensor cost £22 fitting time call it an hour... The digital nonsense is a licence to create work and print money for dealerships
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
Great result and sense of achievement George. Might you have to drop the handle now though ![[Linked Image]](https://www.series2club.co.uk/new_forum/Smileys/wittsends/nixweiss.gif)
Thanks for showing interest guys..... Richard... NO, I am happy to remain a confirmed Luddite.... I earned my coin working with leading edge technologies of many types, thus spurious fault codes, as well as equipment manufacturers who when asked for tec information, hid behind the term intelectual copywright, which ever presented challenges when my interest was in just getting the kit back in action, a lot of which was rather critical.. More than happy to be free of the pressures and frustrations involved.
Posts: 11,526 Likes: 312
Posts: 11,526 Likes: 312 |
That was the reason I bought the MB and not an RR when we decided to try a jacked up wagon, the size of the bills and stories from friends who had owned one of the several models were terrible. Any Diesel V6 had at least one DPF change and the bills were all of that order for a £100 part.
What sort of leading edge thingamies do you play with Luddite ?
Posts: 28,898 Likes: 352
Posts: 28,898 Likes: 352 |
Well done George. There's a good reason I would never update my 30+ year old Defender!
Posts: 1,511 Likes: 21
Posts: 1,511 Likes: 21 |
Mercedes are not cheap either ! My handle lights have gone out! A £25 part but £250 per side to replace as the door panell has to be removed.Beyond a DIY job. I have extended warranty but it does not include bulbs !
Thanks for showing interest guys..... Richard... NO, I am happy to remain a confirmed Luddite.... I earned my coin working with leading edge technologies of many types, thus spurious fault codes, as well as equipment manufacturers who when asked for tec information, hid behind the term intelectual copywright, which ever presented challenges when my interest was in just getting the kit back in action, a lot of which was rather critical.. More than happy to be free of the pressures and frustrations involved.  Not a luddite as I'm happy to embrace and benefit from both old and new technologies. With age  I do appreciate more and more the care and over engineering on older vehicles and mechanics in general though. The lack of computers meant that for any doubt of longevity the next size up fixing was used, specialist parts were hand machined with pride and consideration given to repair and overhaul. The advent of computers and the throw away society gave way to minimising materials used such as to be just adequate with little thought to disassembly or repair. Rosy spectacles I know but there is (short term at least) enjoyment for me in driving or at least appreciating older vehicles, mastering the double de-clutch, using cadence braking etc.
Alistair my good lady had all sorts of issues with her SLK MB so they ain`t what they used to be in our book. Similarly BMW, seems like cost cutting is THE priority for many and has been so for quite some time..? The leading edge kit I worked with will all be old hat by now, but in my time I saw a lot of changes as you might imagine given I started work at age 15 and worked non stop to age 65 on kit of just about every type from Victorian design up to PLC controlled systems with interfaces galore spread over fairly large areas, heavy duty generators. static fire pumps multiple types of automated x-ray machines with interfaces to remote monitoring stations, rotary converters taking in 3ph mains at 50HZ and outputting 600V 400HZ. eventually replaced by solid state conversion processes, also control of circa lengthy circuits initially controlled by saturable core reactors to ensure constant output at predetermined selectable stages and controlled remotely via a mix of digital and manualy operated selection systems, some with partial circuit selective switching using DC injection to kill parts of the main circuit, large semi mobile electro hydraulic mechanical machinery weighing many tons operated via GUI and joystick with smart switch monitoring on a token ring network, with both primary and secondary safety systems....and a whole lot more, but I guess you get my drift...I was two years into retirement before I could finally relax a bit.. The Evoque... if it can throw up all those spurious alarms on the failure of one sensor only, one alarm of which that mattered being a warning of ABS failure, you would imagine the system could be programmed to point you to the wheel speed sensor that was out of step in terms of frequency generation compared to the others, rather than requiring a specialised OBDII programmer to be plugged up before the failed sensor could be identified...... Yeah the folk who create the software are not my favourite kind of people, as it seems their "logic" and priorities seem to somewhat differ from mine... Of course A.I. will resolve all that non-sense...? Graham, seems we may think alike to some degree re the value of old technology.. (-: The friend who plugged in his reader into my Evoque, talked of LR dealerships seemingly inundated with digital dilemmas they were struggling to resolve, whether that might be fake news or not, I have no idea, but could possibly explain a projected seven week wait to be able to book our car in...  Richard, I suspect my Luddite tendencies may be more related to the rate of technological advance which seemed to accelerate exponentially in my last ten or so years in the workplace, whereas I also suspect my ability to cope with it all was reducing, at a time when "customer" expectations also grew at pace, so yeah glad to be out of it all now, but I was for some time at a loss in the early stages of retirement, in terms of sense of place and sense of purpose lost, despite I had more than enough to keep me busy around the house garden and garage.. Were my brain sharper I suspect I might have adopted a similar attitude to yours Richard.. I guess the basis for my Luddite tendencies may be related to the feeling of being robbed of a measure of self reliance, for up until the time electronics and more so digital electronics arrived on scene en mass, I felt more confident when faced with issues that kit could be returned to service by some local means, as it was human sized built by humans designed to be repaired by humans. Once we headed off into modernity at a high rate of knots we became ever more dependant on others supplying parts, designed and built by computers and the humans became increasingly reduced to a necessary interface in the repair process.... Failure to fix, was not an option in the past, whereas now dependant on others, excuses could readily be found, either that or holding a full set of manufacturers spares for every bit of kit with potential to would blow anyone`s budget.... As for having to visit specialist repairers TWICE to have a brake light issue resolved as being in any way acceptable... REALLY..???? Yeah well that is the world we have created with so much unnecessary technology built into so much to further complicate the lives of the general populace, who have little need of much of it.. Farming out responsibility to technology, seems a less than ideal situation, more so when the value of fundamentals seems to be fast disappearing into the mists of time..... But then what else would you expect from a grumpy old man who had two relatively modern machines display failure messages, feeling fortunate that he had at least one pre digital machine in the garage he could fire up with confidence...(-: Simillarly the evolution I type of seems to have created an entirely different mindset in Morganeers who in past times may have been capable of resolving their own issues and today may not even begin to attempt do do so...
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I owned an Evoque for 2 unhappy years... It was the most unreliable thing I've ever owned. The Land Rover dealership was also useless.
I vowed then never to own a JLR product again....
