11 members (RichardV6, Malcolm T, chanteclair, Paul F, dogmog, MartinB60, DJ66, CooperMan, Alistair, MJF, OZ 4/4),
255
Topics48,343
Posts813,021
Posts: 3,665 Likes: 43
Posts: 3,665 Likes: 43 |
At my local Aldi you can buy a heated seat thing which plugs into a lighter socket. I bought one for my mg. £8.95. works brilliantly, takes 30 seconds to fit. Haven't tried it in the mog as the heater is so good.
Posts: 6,057 Likes: 160
Posts: 6,057 Likes: 160 |
Had a set put in when I had my seats retrimmed - there were about £40 from eBay. I have an old trad, so I made some brackets and fitted the switches either side of the heater I also fitted myself. ![[Linked Image]](https://www.tm-img.com/images/2020/10/18/nLT5HPYFa_yPOdxJNFhdioFcdQHdUTS0PdsI3zgaBaXUt96YWJnKCbaMrv2YvPOnMzQhMQnHE046QGbE9vjz0YxA3kmzolxD_EnjSNfNUEnHVWMADOsiJvs3FK9l8Qx9_U8MryjDHGk5tyGDYYfFQ9ac0WmwklT-w2_15v5JCa2O4vVVxIZ9KHaYSgyZRAO0spip5-ig.md.jpg)
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Posts: 7,895 Likes: 241
Posts: 7,895 Likes: 241 |
Had a set put in when I had my seats retrimmed - there were about £40 from eBay. I have an old trad, so I made some brackets and fitted the switches either side of the heater I also fitted myself. ![[Linked Image]](https://www.tm-img.com/images/2020/10/18/nLT5HPYFa_yPOdxJNFhdioFcdQHdUTS0PdsI3zgaBaXUt96YWJnKCbaMrv2YvPOnMzQhMQnHE046QGbE9vjz0YxA3kmzolxD_EnjSNfNUEnHVWMADOsiJvs3FK9l8Qx9_U8MryjDHGk5tyGDYYfFQ9ac0WmwklT-w2_15v5JCa2O4vVVxIZ9KHaYSgyZRAO0spip5-ig.md.jpg) Very neat
Posts: 1,032 Likes: 10
Posts: 1,032 Likes: 10 |
Many thanks for your tips and advice, I have fitted the pads to one seat, I had to remove some c clips to get the cover off slightly so I could get the pad in place. it’s the tombstone recliner so might be different for others.
Now just needs to wire it in. Any recommendations for a easy switched supply one could piggy back off?
Many thanks, Will
Many thanks, Will Will, which model & year ?
Posts: 7,922 Likes: 217
Posts: 7,922 Likes: 217 |
Try any green wire from the fuse box. Most if not all are fed by the ignition switch. I believe fuse 15 feeds the heater fan switch on such a green wire and may be convenient. What ever fused circuit you use, ensure the rating is upped to cover the extra load. I don't think the seat pads take much so an extra 5 amps on fuse rating should suffice.
Posts: 21 |
Hello Will, I have retrofitted heated seats in a 93 plus8. Some fuses have battery voltage, others have ignition voltage. So be careful! I used Lucas 2-stage toggle switches and switched the battery voltage via a relay. If you want, send me your mobile number personally, then we can call via WhatsApp. Greetings from Germany Günter
Sorry for my bad English but school is out since many years
Life is too short to drive boring cars!
Günter, many thanks Will PM you.
I have taken a feed off the Green / Slate wire from the heater switch so the heated seats go on / off with the heater. Which makes it convenient, my only thought is there being enough power for both..
Posts: 510 Likes: 1
Posts: 510 Likes: 1 |
Received my pads yesterday. Thought I may as well fit them because I new I'd have to remove the seats to get the tunnel off to renew the rotoflex coupling, will do the webbing at the same time. A quick check of the wiring diagram shows the switched feeds are white and green or white on my car so will use one of those to control a relay with power coming from a suitable supply, maybe the 50a circuit to a new auxy fuse box.
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
