SORN
New
Topics48,375
Posts813,508
Members9,215
Posts: 3,515 Likes: 8
Posts: 3,515 Likes: 8 |
My wiper stalk has stopped operating, it just doesn't click into position and stay there. It will still operate the wiper at full speed, but I suspect will need replacing.
The problem is that I don't know who the OE supplier is. I was told by someone they thought it was Land Rover Discovery, but having checked I don't think it is. I'm not sure my ARP4 has the same as stalk as all Plus 4s, I'm guessing it does, so, can anyone tell me what vehicle the stalks are from please. I am sure I can make a small saving by buying from a specialist rather than an MMC dealer?
Posts: 199 Likes: 1
Posts: 199 Likes: 1 |
I had the same problem, and bought the wrong one...think I may even have 2....Where abouts are you?
Richard S 1993 4/4 1966 VeloSolex
Posts: 35,802 Likes: 476
Posts: 35,802 Likes: 476 |
Paul, if you send these good folks a picture I'm sure they could help you. Like you I think it's a Disco one but maybe there are a few versions of them. I recall a German colleague on here getting stuck away from home and a Landy dealer had a replacement on the shelf.
Posts: 7,342 Likes: 91
Posts: 7,342 Likes: 91 |
Paul, if you send these good folks a picture I'm sure they could help you. Like you I think it's a Disco one but maybe there are a few versions of them. I recall a German colleague on here getting stuck away from home and a Landy dealer had a replacement on the shelf. Maybe a similar story happened here, but if it was mine, you have a very good memory, Richard. Only in my case it was the rotary switch (in the turn signal lever on the left side of the steering column) for the driving lights. I had only parking light by the error. Whether in the ARP4 the same parts were installed I do not know of course. But in my 2014 4/4 it is from a Freelander!, I don't know what generation of Freelander, but up to 2015 because it happened that year. In the link below is my original post about the breakdown from 2015 with text under the last picture. Really Richard, if you still know that then all respect for your gray cells. http://www.talkmorgan.com/ubbthread...-you-driven-your-morgan-today#Post286892
Paul, if you send these good folks a picture I'm sure they could help you. Like you I think it's a Disco one but maybe there are a few versions of them. I recall a German colleague on here getting stuck away from home and a Landy dealer had a replacement on the shelf. Maybe a similar story happened here, but if it was mine, you have a very good memory, Richard. Only in my case it was the rotary switch (in the turn signal lever on the left side of the steering column) for the driving lights. I had only parking light by the error. Whether in the ARP4 the same parts were installed I do not know of course. But in my 2014 4/4 it is from a Freelander!, I don't know what generation of Freelander, but up to 2015 because it happened that year. In the link below is my original post about the breakdown from 2015 with text under the last picture. Really Richard, if you still know that then all respect for your gray cells. http://www.talkmorgan.com/ubbthread...-you-driven-your-morgan-today#Post286892It was you I was thinking of Heinz, always good to see that the grey cells recall some things, not the right side switch but close  I thought it was great that the garage sorted you out mid holiday.
I found an old photo here (the last two photos in the first long post) of my wiper lever and turn signal lever: http://www.talkmorgan.com/ubbthreads.php/topics/338887/momo-prototipo-fitted-for-4-4When I compare it to this photo of an ARP4 from the net, it looks very similar if not exactly the same. So I am also guessing the Freelander (until 2015 may be even older) as the donor especially since our cars were built at almost the same time. ![[Linked Image]](https://tm-img.com/images/2023/03/08/B21F9109-DB6B-48AC-BECF-CE9258DDACA0.png)
This looks close looking at your last post Heinz ?
This looks close looking at your last post Heinz ? Yes, Richard, and they note the Freelander 1 below in the text, I had not seen your reply.
Posts: 2,064 Likes: 57
Posts: 2,064 Likes: 57 |
Here some postings about stalks Morgan stalks
