1 members (JohnMat),
267
103
Topics49,869
Posts837,666
Posts: 1,520 Likes: 60
Posts: 1,520 Likes: 60 |
Bumpy rides are quite beneficial for those of us with cellulite bottom contours - Of course I am not describing anyone's bottom in particular - But ladies are generally very eager to rid themselves of this less attractive bodily feature  Shaika zatt ass!
Posts: 375 |
![[Linked Image]](https://nsm09.casimages.com/img/2023/03/08//23030804452914798918129382.jpg) bump width : 2.30 m, height ~ 30 mm Ford PUMA 1998 : max 8m/s² (damper less than 5000 km) KA 2002: max 5.7 m/s² MOG 2005... the newest! max: 11.8 m/s² Nota: 1g = 9.81 m/s² ![[Linked Image]](https://nsm09.casimages.com/img/2023/03/08//mini_23030804594914798918129400.jpg)
Regards 2005 PLUS 4
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
What does all that mean and what benefit is it?
Posts: 375 |
Scientific curiosity... it is not necessary in life.
In France we don't have Heinz Baked Beans and our lives could be good.
Regards 2005 PLUS 4
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
Thanks CBY. It would have been good to compare results from before and after I had the ssl suspension mods fitted.
Also I think our evoque has a harder ride than our merc GLC. I think I’ll have a go at this
It might be addictive, have you tried any other comparisons?
SFG 2012 4/4 Sport
Posts: 375 |
I made the SSL conversion in july 2017 and now cannot make the comparison except with a friend having a PLUS 4, but not the same car. Perhaps i could have the oportunity to do it in the future.
I made some years ago a mathematical model of half of the front suspension with Scilab in order to compare the both configuration. I found a significant difference on the paper. The only problem with a model is to adjust it with a real item. But in my case this is impossible. In the model I use sinus excitation and the difficulty is to find a road with a sinus profile!
On the road with my Mog we found a real improvement (with my bum, RichardV6 method). Not to bad.
Regards 2005 PLUS 4
I’m convincing myself that the SSL upgrade is better. It didn’t seem to be at first, as adjusting the shock absorber settings seemed to make no difference. Perhaps the new kingpins bushes were very tight. I’d like to try the comparison with different shock absorber settings, now that I’ve done a few miles. Maybe you’ll get there first.
SFG 2012 4/4 Sport
Clearly I am no scientist but I am trying to understand this! Surely when comparing the "bounce" of different vehicles the weight + distribution of said weight along with size of wheel/tyre + tyre pressure must be taken into consideration? By the way Heinz Baked Beans make a considerable difference to the comfort of a Morgan ride
I think that’s right. My backside says the merc rides better, it would be good to see some quantification. I have worked out that they are different vehicles with different tyres. And I think the Heinz effect is to provide a regularly replenishing air cushion under the drivers substructure
SFG 2012 4/4 Sport
