2 members (DirkM, BobtheTrain), 152 guests, and 49 robots.
Posts837,249
Or a 19mm plywood off cut - say 150 x 150
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
In our old 4/4 we once had a puncture on the A50 dual carriageway. Limped to a slip road and changed the wheel. Jacking on tarmac, the factory jack was perfectly adequate. No sign of toppling or slipping. In this instance, as it was a rear wheel, I jacked the car under the spring close to the rear axle so the lift required was minimal.
It was our wedding anniversary and by the time I had changed the wheel, we had lost interest in our planned run to Dovedale. Ended up in a nearby pub for lunch.
Costock, UK
Disco 5
And these show the jack in question being used on the front in the pitstop challenge at Newmarket. This is the DonMog ladies team.
Costock, UK
Disco 5
I always carry a can of that puncture repair stuff....not necessarily a permanent fix, but enough so you can maybe change the wheel in a safer place...
Richard S
1993 4/4
1966 VeloSolex
Re that squirty puncture repair stuff, I always carry a can in my tin top, but is it ok to use on wire wheels ??
pheasant #771509 15/03/23 09:49 AM
Black Rat
Black Rat
It will probably work but then you will likely need to have the rubber seal replaced at MWS.
Keith
2013 narrow bodied + 4 Ruby.
pheasant #771510 15/03/23 10:04 AM
I imagine it depends on whether you are using innertubes...if you are, I can't see how it could work.
I'm often wrong though.....
nick w #771629 16/03/23 11:18 AM
Black Rat
Black Rat
Modern W/W are tubeless and shouldn't be fitted with tubes.
Keith
