1 members (sprinty),
304
52
Topics49,860
Posts837,486
Posts: 95 |
What a resource TM is. I went to take my M3W out a month back after it had been laid up for a couple of months. Just before i hit the button, i remembered reading posts re "wet sumping". Sure enough there was much less oil in the tank than i expected. Ran through the process as suggested on here and oil returned to the tank. ££££££s saved. Thank you to those that shared their knowledge and experience.
A couple of weeks back, a crashed M3W was advertised here. There is a guy in the US who has suffered two crank failures whilst under warranty and has been abandoned by Morgan. Surprisingly he his not on here so i put him in touch with the seller and the deal has been done. He will soon be back on the highway.
To the Morganistas out there sharing issues is not moaning. It is helping.
I am reminded that i must make a financial contribution to the running of this resource.
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
Good reminder on donations to this excellent resource
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Looks like nothing has changed with the level of Morgan support of their product....
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Looks like nothing has changed with the level of Morgan support of their product.... And I doubt the MMC corporate attitude will ever change. I would love to see what the Japanese would produce if they were given a V-Twin to have on the front end and everything else in the drive train was up to them. I bet whatever they produced would be way more reliable.
Posts: 22 |
Which process did you go through to return the oil, as I've seen a few suggested.
Posts: 95 |
Which process did you go through to return the oil, as I've seen a few suggested. Depress clutch and and attempt to start (which as you will know it will not) a couple of times. I was surprised how much oil had left the tank and how quickly it was returned.
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
Which process did you go through to return the oil, as I've seen a few suggested. Depress clutch and and attempt to start (which as you will know it will not) a couple of times. I was surprised how much oil had left the tank and how quickly it was returned. This method will probably work, but does run the risk of blowing the crank and/or pinion seals as well as spewing oil into the air filter. A safer method is to drain the oil into a clean container via the sump plug and then pour it into the oil tank.
Andy
Posts: 95 |
Which process did you go through to return the oil, as I've seen a few suggested. Depress clutch and and attempt to start (which as you will know it will not) a couple of times. I was surprised how much oil had left the tank and how quickly it was returned. This method will probably work, but does run the risk of blowing the crank and/or pinion seals. A safer method is to drain the oil into a clean container via the sump plug and then pour it into the oil tank. I will not do that again then but if you can strip your plug, i definitely can. Just checked and lost plenty out of the tank again after just 3 weeks.
Posts: 1,035 Likes: 36
Posts: 1,035 Likes: 36 |
On older British motorcycles some owners used to fit a stop tap at the oil tank outlet which was closed manually after the engine had been stopped. It works, of course, but the consequences of forgetting to open it don't bear thinking about. There was also an anti-drain valve fitted to Norton Commandos and others which allegedly stopped the oil tank draining out. This was totally automatic and hence foolproof. There may be a proprietary item available in the Harley Davidson aftermarket. The other alternative is to start your engine more frequently.
Posts: 95 |
On older British motorcycles some owners used to fit a stop tap at the oil tank outlet which was closed manually after the engine had been stopped. It works, of course, but the consequences of forgetting to open it don't bear thinking about. There was also an anti-drain valve fitted to Norton Commandos and others which allegedly stopped the oil tank draining out. This was totally automatic and hence foolproof. There may be a proprietary item available in the Harley Davidson aftermarket. The other alternative is to start your engine more frequently. Just read through the earlier threads which also mentioned taps etc. Maybe over worrying. Nothing is leaking or blowing out. Thanks for all advice
