6 members (lord-richfield, Topline123, John07, mph, MartinB60, CooperMan), 289 guests, and 40 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,342
Members9,215
Edwin Offline OP
I'm not getting fuel to the carbs.
Replaced fuel pump, no juice!
Sucking on line is fruitless.
Air Pressure didn't find leaks in line/tank. Line is clear.
Disconnected the pickup line at the top of the tank to reveal a 90 degree fitting, with nothing inside to get to the petrol.
What should be attached to the inside of the fitting to reach near the bottom of the tank?
65 Plus 4 / 4 Seater, car addict
Edwin Offline OP
Morgan Spares says there should be a pickup line attatched to the 90 degree fitting, extending to the bottom of the tank.
Should I be worried about the old pickup flopping around inside the tank?
If you take out the fuel sender the opening may be wide enough to find a way to fish the pipe out ... if I remember from mine the pipe was a length of metal tube.... can't see it doing much if it is left in the tank if removal proves too difficult
Ps ... smoking on the job is probably inadvisable 🙂
Could you not use a cheaply available borescope camera in conjunction with extended pickup claws to retrieve loose pickup pipe?
If it was plastic it might have dissolved in E10 or even E5. I have had that problem with my garden power tools.
2025 MG ZS EV aka Trigger
Magnet on a bit of old accelerator cable/choke cabledown down the fuel filler cap works a treat.
But when it comes to replacing it.
Mind you, I always install a filter on the pick up pipe to stop the crap in the bottom of the tank reaching the fuel pump - a paint filter sold for use on the pickup tube on a paint spray gun is idea as it is petrol/solvent proof.
To do this you will need to remove the fuel gauge sender
Arwyn
Edwin Offline OP
I live in an area where Ethanol Free fuels ate abundantly available. Can't imagine using E-anything in any of my vehicles.
TBM Offline
Can't get anything but E fuel here. E10 or E5. E5 is supposed to be near enough ethanol free in some ares of the UK but I'm not convinced.
I've fitted a stainless tank, and ethanol resistant hose so no concerns and not noticed any issues. I use E10 mostly, with the occasional squirt of E5 when I'm feeling flush.
