8 members (PaulyG, Sir Percival, hugo, Heinz, +8Rich, RichardV6, BillHart, mph),
417
44
New
Topics48,365
Posts813,387
Members9,215
Posts: 11 |
I've noticed an unusual 'knock/clunk' that has developed if I launch the car in 1st gear. It only happens in 1st gear. It only happens if you launch the car. A 'normal' pull away from a standstill or even under half throttle doesn't replicate the noise, and the noise only ever happens once at a time.
I am confident it is not the engine, I almost feel its behind me or possibly the transmission tunnel...
Any idea what it could be?
My first thought was the drive belt skipping a tooth, although I am worried it's something else as I'm sure this never used to happen.
19 plate car with 4k miles.
Posts: 7,944 Likes: 218
Posts: 7,944 Likes: 218 |
Nose of bevel box hitting chassis maybe given vaguries of NVH mounting. Check for witness marks.
Posts: 1,613 Likes: 22
Posts: 1,613 Likes: 22 |
Most likely NVH kit hitting chassis at the front end just behind the gear box. My first M3W would give a couple bangs on a a full throttle getaway, I removed the NVH kit and fitted the Bleazey bevel box mount and it stopped doing it. my current M3W current doesn't do it
Posts: 11 |
Thank you, both.
Is this just a characteristic of the car or would something mechanically be fundamentally wrong that has allowed this to happen?
While I don't launch very often, I am sure it didn't do it before last week... But I don't launch frequently enough to actually remember for certain.
Posts: 284 Likes: 21
Posts: 284 Likes: 21 |
Just check belt isn't too slack and do a spanner check on the NVH kit - front bolts at gearbox rear mount might nip up a quarter of a turn and same with the bottom rear 2 bolts where it mounts across the chassis. If the belt isn't slack then personally I'd just live with it if its only when you 'launch' the car.
