0 members (), 308 guests, and 46 robots.
+8Rich 93
Posts837,277
I
I
Hi Mike,
Will do.
Ian
Would Litchfield do the brake pads for a Plus Four as well?
Heron Grey Plus Four 2021
Previous:-
Connaught Green 4/4 1988
Black Plus 8 1998
I
I
Not sure, probably best to phone them
Ian good evening.
Did you manage to get alternative pads?
Like you I think the standard ones are not good.
I have tried but failed to find alternative ones.
Thks
Russ
I
I
Hi Russ
Not yet, getting there though.
Taking photos of calipers to send to Lichfield, who will then liaise with Pagids and ensure correct RS29 pads are supplied. Once I have the pads will get them fitted.
Cheers
Ian
I tried Deemon Tweeks on pads.
Simple answer was draw them and measure them as we have no idea!
I
I
Hi Russ
I have just spoken to Litchfield and sent the photos. They will liaise with PAGID in Germany and revert.
Cheers
ian
Smile, it confuses them
The peeps at EBC are very accessible and experienced. I have spoken directly to some very technical guys in the past. They also have a variety of lining strengths.
I got a set of upgraded discs from them for the ML63 and whilst clunky when cold they are a big step up when warmed. The yellow pads do give off dust but are great when you want to push on or track day the car. Not an ML63 clearly, it would wipe out half a county if you lost it.
I
I
Hi Alistair,
Thanks for the info. Looks like I have a backup if I don’t hear from Litchfield. 👍
Cheers
Ian
