Topics49,849
Posts837,415
Posts: 1,047 Likes: 148
Posts: 1,047 Likes: 148 |
End up with plenty of power. ![[Linked Image]](https://i.ibb.co/3040whL/Newman-PH2-cams-Fusion-Fab-Inlet-Manifold-190bhp-6500-but-carries-on-climbing-to-203bhp-7200rpm.jpg) But with heaps of usable torque right where you need and use it on the road. ![[Linked Image]](https://i.ibb.co/G7sMFWQ/Newman-PH2-cams-Fusion-Fab-Inlet-Manifold-190bhp-6500-but-carries-on-climbing-to-203bhp-7200rpm-smil.jpg) Make lovely noises to put a smile on your face https://www.youtube.com/shorts/UzKMKOA3qGIJob done, well not quite yet actually
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
I thought aural pleasure was something else entirely
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 37,408 Likes: 977
Posts: 37,408 Likes: 977 |
I thought aural pleasure was something else entirely  Wrong website - Google Stormy Daniels  Donald knows how to spell it as did Bill Clinton and Monica
Posts: 16 |
Monty's upgrade looks fantastic and very interesting. I'm contemplating something similar. Quick question, as I'm new too Morgan and the Ford Duratec engine?
General question?: With regard to motorway cruising, rather than just accelerating:-
My engine is currently stock, runs very smoothly up until 3000rpm, but at round 3500rpm it seems mechanically harsh, or perhaps I would describe it as more of a resonance. Its very noticeable as the engine moves above 3000rpm, certainly not a linear change. Is this typical with the Duratec?
Otherwise the engine seems fine, has only 27000 miles and is in good order. No issues found with an OBD reader.
193 FLN 2009 Narrow Body +4
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
Could it be purely mechanical .... the engine twisting slightly in it's mountings as it works harder allowing something like the exhaust to touch the body/chassis?
Posts: 16 |
The exhaust touching the chassis seems a good place to start. Thanks.
The car also has SSL suspension front and rear, although I can't think how this could cause resonance.
If this occurred at 4500rpm+ you might expect it, but 3500rpm is quite gentle imo.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Give everything attached to the engine a good 'wiggle' especially air boxes / filters, sometimes tapping things with a rubber hammer will show up a rattle like loose baffles in silencers, also look at the exhaust bobbins as they often look ok but have delaminated between rubber and the metal flange face
