11 members (Montegue, Alan Patterson, High Hamster, Tom Sayles, Guern, britmog, +8Rich, RubyMog95, Graham, G4FUJ, JMcL, tommog),
287
111
Topics49,868
Posts837,645
Posts: 8 |
I seem to have a duff fuel pump relay ... but I dont seem to be able to find the relay and the INJ fuse position is empty , Help
1995 Plus 8 Corsa Red
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
The fuses and relays have moved about over the years.
Earlier cars seem to have the relays under the dash. On my 2005 they are in a block directly above the steering column, so start by looking under the dash.
Someone will be along soon with a similar aged Morgan who should know.
Posts: 37,433 Likes: 978
Posts: 37,433 Likes: 978 |
On my 1999 Plus 8 there are two relays on the horizontal part of the bulkhead ahead of the driver under the bonnet one of which is the fuel pump relay and the other the cooling fan relay.
Posts: 160 Likes: 12
Posts: 160 Likes: 12 |
On my 2001 +8 there is only one relay under the bonnet which is for the radiator fan. I was said that the electric fuel pump is directly driven by the GEMS ECU. The only failure I ever had was a bad contact at the fuel pump lugs. They were completely charred, blackened by the arcing that occurs at that point due to the high amperage. A simple energetic cleaning with sandpaper solved the problem by restoring a good contact. Better to have a look a these tiny lugs.
Happy Morgan +8 (2001) owner BMW 435i - X Drive Royal Enfield 500 EFI Royal Enfield 650 Interceptor
Posts: 2,223 Likes: 182
Posts: 2,223 Likes: 182 |
On my 1999 Plus 8 there are two relays on the horizontal part of the bulkhead ahead of the driver under the bonnet one of which is the fuel pump relay and the other the cooling fan relay. Same on my 1994 +8.
Posts: 8 |
thanks guys . I found them behind the glove box on the passenger side . New relay fitted and the engine fired up . New problem .. after a few minutes tickover engine began 'hunting' then cut out . It started again but then cut out again ???
That sounds like a fuel starvation issue, on start the pump is priming but then not continuing to run.
Posts: 5,447 Likes: 469
Posts: 5,447 Likes: 469 |
If there is a fuel filter in the supply line perhaps it is partially clogged up...?
Posts: 8 |
Thanks guys . The car seems to rev ok . Its been stood with half a tank of fuel for about six months .Could it just be condensation air locks and injectors in need of a clean / blast through . Is STP injector cleaner any good , A friend with an old classic car said I should try that before I start pulling things to bits .
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
If the fuel really is six months old then it might just be stale fuel.
