0 members (), 395 guests, and 92 robots.
+8Rich 81
Topics49,849
Posts837,424
If the idle isn't smooth, check the MAF. Mine needed a clean before 20k miles. It was slightly oily, and a squirt of cleaner fluid resolved it.
Worth checking,( especially with K&Ns).
Leroy Offline OP
Thanks Dave, MAF has been cleaned, and then changed. Also cleaned the IAC valve, changed standard air filter and spark plugs. Next up will be the leads. I've had all manner of additives put in the fuel to clean the injectors also. It's not an issue as it never stalls, just when you are used to a perfectly smooth running engine in the tin top, it's just a bit irritating.
2004 Series 1 Roadster
Leroy Offline OP
Originally Posted by Felix42
I've just had the alternator voltage on my 2005 series 1 Roadster tested and it's giving 13.9 volts.
Was your engine warm, or was this from a cold start. might do a variety of tests, from cold, warm, with load and without,to see what I get.
It was tested during a service & MOT visit to Berrybrook - I assume the engine was warm
Coil pack ? even OE Ford one's are only about £60 ish
Leroy Offline OP
Never considered that. Don't mind shelling out £60, but is there a test I could do to see if that could be the cause?
Black Rat
Black Rat
Try pulling the plugs after rough running, see if any are wet/different colour.
Keith
2013 narrow bodied + 4 Ruby.
Leroy Offline OP
[/quote]
I changed the plugs last year so that could be an idea as any colour change would be obvious. One was a bit wet, but I did squirt some wd40 down the hole as the plug was tight, so this might have been why.
Whilst WD40 might be used on the threads of a plug to help clean them up, squirting it down the plug hole is not advised as it can create carbon deposits on the plug and cause issues. Well documented if you google.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Umm, not really a technical one, but symptoms similar to yours, like lumpy tickover, hesitation on acceleration, lack of torque, tend to point to a coil pack failing (buy a decent branded one, not some fleabay copycat crap)
