Topics49,860
Posts837,484
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
Pleased you have located the problem Ian!
Posts: 8,671 Likes: 408
Posts: 8,671 Likes: 408 |
Holden seem to have switches Ian here. Given others have had similar problems might be useful to carry a spare whilst still available.
Posts: 502 |
Discovered something odd today, an guessing it might be relay related. All indicator lights are working. Turning left normal, hazards work as normal, but turning right, they are rapid, like you get when you have a bulb out, but they both flash. If this is a relay issue, can anyone advise where it is, and which one it is to replace please. I'm guessing it's under the dash, above the gear stick. TIA
2004 Series 1 Roadster
Posts: 5,587 Likes: 603
Posts: 5,587 Likes: 603 |
If you turn on your sidelight or press the brakes do these flash/flicker as well ? ... if so suspect the earth first.
Posts: 5,440 Likes: 131
Black Rat Charter Member
Posts: 5,440 Likes: 131 |
Yes I would suspect earth or a fault in one of the bulbs even though they flash.
Posts: 502 |
The side that's flashing fast, the rear bulb is dimmer. Last year this bulb wasn't working and caused the same rapid flashing as you'd expect. It was due to a corroded connector that I solved by cleaning it up some what by squirting electrical cleaner inside. Maybe if the contacts are poor again, it isn't drawing as much power to that bulb, therefore causing the rapid flash. Could this be the case?
Posts: 502 |
K Tried this and all good.
Posts: 502 |
All cured. Burgundymogs suggestion got me thinking about the wiring. A good squirt of electrical cleaner into the connectors and it cured the problem.
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
Posts: 16 |
Gents, I have a similar problem with my 2001 4x4 Morgan 25000 miles on the clock ( true milage ) I have recently fitted a new fuel pump, as the one in the tank stopped working so now the engine is running well, all dashboard light working all gauges working, But only the main beam flash works when the indicator switch ( left hand side of column ) is depressed etc, when i depress the rocker switch for the main lights ( right hand side of the steering column on the dashboard ) the lights do not come on, No indicators work no flashers work, the wipers work but no external lights work, not sure if the break light are working when the pedal s depressed, I'll get her indoors to have a look
any idea's what the problem could be, all fuses look good three new relays fitted from Brands Hatch Morgan
