8 members (Morganmike, nick w, Graham, G4FUJ, MOGDave, Hamwich, uvk33n, AlyMatt, Deejay),
241
Topics49,914
Posts838,190
Posts: 81 Likes: 1
Posts: 81 Likes: 1 |
In preparation for changing the rear differential oil I was under the car but the drain plug isn’t obvious. There are a ring of bolts which I assume bolt on the diff cover so wondering if the bottom one acts as a drain plug?
Would anyone know what the axle type is also?
Thanks.
Kevin Davies
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Just looking through some pics of my 2016. 4/4, and I can’t see any drain plugs either ? Perhaps mine was pumped out, in last picture here 2 years ago at Williams. I’m sure someone will be along soon with the answer ![[Linked Image]](https://tm-img.com/images/2023/04/05/835D2E55-DEA6-4C36-B14D-AF629D9EE62D.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/04/05/2808E9AF-BCBE-4795-9757-6471BC196067.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/04/05/E7CD8426-4422-4C3F-A483-030ACD597C19.jpeg)
Craig Jezz
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
Thanks. Yes, bottom one is drain plug (NON'T drain it yet) Make sure you can get to the filler plug, it's about half way up the rear cover, depending on the age some use a large AF spanner (or good adjustable) some use a sort of recessed allen key hex socket, make sure you can access and loosen the filler BEFORE draining, or you'll end up with an empty diff & be stuck at home
Posts: 412 Likes: 10
Posts: 412 Likes: 10 |
On my 2009 4/4 the bottom bolt is the drain plug. It looks just like all the others around the diff cover plate but it doubles as a drain plug. To refill I pumped it up into the fill hole. i don't have a photo I'm afraid but there is a good illustration on https://www.gomog.com/allmorgan/btr.html#FillingGood luck
2009 4/4 Sport in Red 2022 Harley Davidson FXLRS Low Rider S 1977 Triumph Stag
Posts: 81 Likes: 1
Many thanks chaps for confirming and yes I’ll be sure to loosen the fill plug before draining the oil.
Kevin Davies
Just looking through some pics of my 2016. 4/4, and I can’t see any drain plugs either ? Perhaps mine was pumped out, in last picture here 2 years ago at Williams. I’m sure someone will be along soon with the answer ![[Linked Image]](https://tm-img.com/images/2023/04/05/E7CD8426-4422-4C3F-A483-030ACD597C19.jpeg) Blimey Matron...that's a whopper
Posts: 37,490 Likes: 994
Posts: 37,490 Likes: 994 |
A photo copied from Dave's how to service a Roadster page. ![[Linked Image]](http://tm-img.com/images/2023/04/05/di.jpeg) ![[Linked Image]](http://tm-img.com/images/2023/04/05/P1000628.jpeg)
Posts: 8,704 Likes: 416
Posts: 8,704 Likes: 416 |
How can a car that clean underneath possibly need the diff oil changing just yet
It's Dave and it will be a 5th April thing  Time to put some more away in the ISA too tomorrow.
Posts: 488 Likes: 27
Posts: 488 Likes: 27 |
What's the service interval for this? Mine is a 16 plate and serviced every year at a mains dealer. I don't ever recall being asked/told to change the diff fluid.
Thanks!
