2 members (Rovert, Bitsobrits), 334 guests, and 44 robots.
John V6 70
DaveW 66
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,996
RedThree
Alpha1 Offline OP
In preparation for changing the rear differential oil I was under the car but the drain plug isn’t obvious.
There are a ring of bolts which I assume bolt on the diff cover so wondering if the bottom one acts as a drain plug?
Would anyone know what the axle type is also?
Thanks.
Kevin Davies
Just looking through some pics of my 2016. 4/4, and I can’t see any drain plugs either ?
Perhaps mine was pumped out, in last picture here 2 years ago at Williams.
I’m sure someone will be along soon with the answer
Craig Jezz
Thanks.
Yes, bottom one is drain plug (NON'T drain it yet)
Make sure you can get to the filler plug, it's about half way up the rear cover, depending on the age some use a large AF spanner (or good adjustable) some use a sort of recessed allen key hex socket, make sure you can access and loosen the filler BEFORE draining, or you'll end up with an empty diff & be stuck at home
On my 2009 4/4 the bottom bolt is the drain plug. It looks just like all the others around the diff cover plate but it doubles as a drain plug.
To refill I pumped it up into the fill hole.
i don't have a photo I'm afraid but there is a good illustration on https://www.gomog.com/allmorgan/btr.html#Filling
Good luck
2009 4/4 Sport in Red
2022 Harley Davidson FXLRS Low Rider S
1974 Honda CB450K7
Alpha1 Offline OP
Many thanks chaps for confirming and yes I’ll be sure to loosen the fill plug before draining the oil.
Kevin Davies
Blimey Matron...that's a whopper stars
A photo copied from Dave's how to service a Roadster page.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
How can a car that clean underneath possibly need the diff oil changing just yet innocent
It's Dave and it will be a 5th April thing wink
Time to put some more away in the ISA too tomorrow.
2009 4/4 Henrietta
What's the service interval for this? Mine is a 16 plate and serviced every year at a mains dealer. I don't ever recall being asked/told to change the diff fluid.
Thanks!
