3 members (lez, John V6, JMcL),
158
79
Topics49,887
Posts837,880
Posts: 1,155 Likes: 2
Posts: 1,155 Likes: 2 |
Has anyone any experience of getting access to the washer bottle on a Aero plus 8 .Mine is leaking and it looks like quite a job to get at it inside the N/S wing .
Posts: 37,454 Likes: 988
Posts: 37,454 Likes: 988 |
No experience at all of Aero chassis but going by the inbuild shots posted on here it will be a wing off job, good luck.
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
Looking at Aero's in build...it's a wing-and-prayer job
Posts: 2,432 Likes: 17
Posts: 2,432 Likes: 17 |
Takes only a few minutes to remove a Aero wing, simply unscrew the turn screw fasteners and disconnect the lights. .
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 8,688 Likes: 414
Posts: 8,688 Likes: 414 |
Hopefully you have the parts manual for your car Peter, but if not it's available for download here and below is screenwash page if it helps. ![[Linked Image]](https://i.imgur.com/Acg9tjN.png)
I have the parts diagram thanks Richard . I’m going to leave it for a while , as the air filter is in there too , so service time should sort it .
Posts: 5,659 Likes: 10
Posts: 5,659 Likes: 10 |
20 minute job to remove the wing.
Martin (Deano)
Posts: 11,534 Likes: 318
Posts: 11,534 Likes: 318 |
I take it the leak is coming out from the wing area? I ask because the pipes around the screen nozzles are known for coming loose and leaking into the back of the dash. This leads to a lot of problems including cut-out and rainbow dashboard events. It is always worth checking those fittings as I believe they are interference fit.
Posts: 51 |
I had a leak on the filler neck pipe only so worth checking that.
I have the parts diagram thanks Richard . I’m going to leave it for a while , as the air filter is in there too , so service time should sort it . Pete, sort it at my place when the weather improves if you want ?
