Morgan Aero 8
4 members (Topline123, Graham, G4FUJ, The Flitting, MJF), 212 guests, and 101 robots.
+8Rich 74
Luddite 50
Hacked email account
by +8Rich - 08/09/26 01:47 PM
Guess the car
by Soleng - 07/09/26 06:44 PM
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Topics49,888
Posts837,883
#774216 09/04/23 03:48 PM
MR11MOG Offline OP
Has anyone any experience of getting access to the washer bottle on a Aero plus 8 .Mine is leaking and it looks like quite a job to get at it inside the N/S wing .
Peter.
Aero plus8 50th Anniversary.
No experience at all of Aero chassis but going by the inbuild shots posted on here it will be a wing off job, good luck.
Looking at Aero's in build...it's a wing-and-prayer job wink
Takes only a few minutes to remove a Aero wing, simply unscrew the turn screw fasteners and disconnect the lights.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Hopefully you have the parts manual for your car Peter, but if not it's available for download here and below is screenwash page if it helps.
MR11MOG Offline OP
I have the parts diagram thanks Richard .
I’m going to leave it for a while , as the air filter is in there too , so service time should sort it .
Peter.
20 minute job to remove the wing.
Martin (Deano)
Smile, it confuses them
I take it the leak is coming out from the wing area? I ask because the pipes around the screen nozzles are known for coming loose and leaking into the back of the dash. This leads to a lot of problems including cut-out and rainbow dashboard events. It is always worth checking those fittings as I believe they are interference fit.
I had a leak on the filler neck pipe only so worth checking that.
Pete, sort it at my place when the weather improves if you want ?
