7 members (John Winn, Ian Wegg, Plus Four Guy, linklaw, AndyGoff, MartO, Image),
298
53
Topics49,859
Posts837,497
Posts: 472 Likes: 70
Posts: 472 Likes: 70 |
In the 1960s when I worked in a service bay I was told to use the copper washer on the engine drain plug if fitted and for the rest of the engine, gearbox and back axle just nip up the drain/filler plugs. No fancy sealants, never had any leaks. Back street boys? The drain/filler plugs without washers are usually slightly tapered so they lock in when tightened. I never used a sealant.
1956 Plus 4 4 seater
Posts: 6,669 Likes: 434
Posts: 6,669 Likes: 434 |
In the 1960s when I worked in a service bay I was told to use the copper washer on the engine drain plug if fitted and for the rest of the engine, gearbox and back axle just nip up the drain/filler plugs. No fancy sealants, never had any leaks. Back street boys? Correct - Sump plug usually has a straight thread so needs a washer, gearbox and axles usually have a taper thread so 'should' seal themselves, but over time the threads wear.
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
I generally use a little PTFE tape too...
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
