Topics48,351
Posts813,146
Members9,212
Posts: 401 Likes: 42
Posts: 401 Likes: 42 |
In the 1960s when I worked in a service bay I was told to use the copper washer on the engine drain plug if fitted and for the rest of the engine, gearbox and back axle just nip up the drain/filler plugs. No fancy sealants, never had any leaks. Back street boys? The drain/filler plugs without washers are usually slightly tapered so they lock in when tightened. I never used a sealant.
1956 Plus 4 4 seater
Posts: 6,057 Likes: 160
Posts: 6,057 Likes: 160 |
In the 1960s when I worked in a service bay I was told to use the copper washer on the engine drain plug if fitted and for the rest of the engine, gearbox and back axle just nip up the drain/filler plugs. No fancy sealants, never had any leaks. Back street boys? Correct - Sump plug usually has a straight thread so needs a washer, gearbox and axles usually have a taper thread so 'should' seal themselves, but over time the threads wear.
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Posts: 2,396 Likes: 14
Posts: 2,396 Likes: 14 |
I generally use a little PTFE tape too...
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
