8 members (JohnHarris, MartO, MATTMOG, Sir Percival, Anonymouse, TalkMorgan, Zach, DickJ), 233 guests, and 36 robots.
+8Rich 101
John V6 59
Topics49,912
Posts838,164
Georgetoad, woolfie
#775449 23/04/23 06:41 AM
Got annoyed with myself yesterday. Have me when parking out of the garage the first scratch on the paint pulled. has someone experience with paint touch-up or should I go straight to a painter. Am grateful for any tip
Clemens
PlusFour Red Baron MY 2022
CLPlusFour #775453 23/04/23 07:02 AM
I know how you feel Clemens, my car had almost identical damage caused by the ratchet strap when it came off the trailer.
The factory provided the paint code and the local paint shop managed to stop the paint on the edge of the raised area on the arch. Mine is metallic and honestly you cannot see any sign of the repair in any light conditions. So I suggest taking the car to the paint shop. Good luck.
Gordon Duguid
CLPlusFour #775455 23/04/23 07:14 AM
Thanks Gordon for the feedback and the encouraging words ... that makes me already confident that the damage can be repaired again
Clemens
CLPlusFour #775467 23/04/23 08:52 AM
Where your damage is, you could just order a touch up pen which also has a little brush inside it, and just paint it over the scrape. On very close inspection you will see it, but I can guarantee, after a while, you'll forget about it, and it won't even register with you. Good that it's not on a flat surface in the middle of a panel that would really stand out.
2004 Series 1 Roadster
CLPlusFour #775469 23/04/23 09:15 AM
Sorry to hear Clemens. The best solution depends on your character. The location of the scratch and the fact it's a brand new car, I should suggest that because it's fortunately on a perfect spot for spot repair let have it done professionally, won't cost too much, and you can at least forget about it......!! Would be my choice! Good luck with it!👊🙋🏼‍♂️
Ruut Bianchi
CLPlusFour #775472 23/04/23 09:37 AM
Beware using Morgans own touch up paint pens, the one supplied for our Plus Six ( with correct paint code ) was nowhere near the colour. A paint repair specialist made up a touch up pen for us that matchs the cars paint.
Also, having dabbled with a few paint jobs on motorcycles and looking at the size of the scrape and its location, I would suggest a "smart" repair. In the UK there are mobile specialists that will come to your house and repair it on site for not huge money. That scrape could easily be repaired using an airbrush, although its worth noting that if there are any marks into the alloy, then it may need a little body filler first and then an etch primer so that the paint bonds correctly to any exposed alloy. Then the colour coat and clear coat goes on. I am sure it can be fixed to be a invisible repair.
Dave
Plus Six "Squeak"
Roadster departed.
CLPlusFour #775480 23/04/23 10:29 AM
X
X
Touch up paint isn‘t a good idea.
Ask for a specialist for „smart repair“. Mustn‘t be your dealer.
Look for good quantity and named bodyshops.
Greets René
Lackstift ist keine gute Idee, auch Sprühdose ist nicht so toll.
Ich hatte ein ähnliches Problem. Am ersten Tag zurück in Deutschland hatte ich massive Kratzer auf dem vorderen Kotflügel.
Durch den Selbstimport war das Auto noch in GB versichert und wurde dort repariert.
Es gibt spezielle Betriebe für „Smart repair“. Hier einfach mit der Autowerkstatt deines Alltagsautos fragen mit wem die zusammen arbeiten. Grundsätzlich haben viele Autohäuser deutscher „Premiumhersteller“ eine Kooperation. Der Farbton sollte kein Problem sein, hier wird in der Regel immer eine Farbanalyse gemacht.
Lack ist bei Morgan übrigens ganz normaler wasserbasierter Autolack.
Viel Erfolg und Gruß aus Mainz
René
2018 plus4 (sports green)
CLPlusFour #775487 23/04/23 11:23 AM
Clemens, really sorry to read this, we have all done it.
Considering the newness and value of your car I definitely think you need to have a professional outfit complete the job for you.
You probably have some very good "at your home" repair outfits in Germany and a recommendation is handy, your local car club will know of someone..
CLPlusFour #775489 23/04/23 11:40 AM
Vielen Dank René. Das mach ich so 👍
Thanks Richard... will visit a professional auto painter 😀
Thank you all ... my mood is already better again 🤗
Clemens
CLPlusFour #775492 23/04/23 12:11 PM
Clemens
as has been written here several timies: Paint Touch would not be effektive.
It looks like the allu at the wing also has some scratches so Best way is to as some paint shops.
I understand your feelings quite well - but there are more expensive mistakes one can make.
I remember that it took me only two days to let my hood scratch my New Morgan Park stearing wheel.
I did see this marks on every trip and when I did not look at tbe scratches I did feel them.....
